First post, by medz16
Hi there!
I've been browsing around for a while and can't seem to find the fix to my problem. Whenever I try to fun the full/registered version of Hocus Pocus, I get a message reading "This program must be run under Win32." The shareware version runs fine. I'm using DOSBox.74 on OSX 10.5.8. Any advice?
Thanks! ~megs
Reply 2 of 12, by medz16
I just don't understand why the shareware runs and the complete game doesn't? They're both listed as "supported" on the DOSBox website.
Reply 3 of 12, by SKARDAVNELNATE
Run it in Windows, see what happens.
Reply 4 of 12, by wd
Rank DOSBox Author
DOSBox Author
Where is that "registered version" from?
Reply 5 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
you are probably trying to run the installer in dosbox.
Water flows down the stream
Reply 6 of 12, by medz16
If I had a Windows machine, I would.
The registered version is from me buying it from the 3D Realms site ($6, not a big deal).
The download did not include an installer, just Hocus_pocus.exe. The shareware download came with an installer, which I did have to run in dosbox.
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
Check their specs if they claim it runs on non-windows systems.
Any way your best bet is to use some file extraction tool to unpack
the whole installer (7zip may work).
Reply 9 of 12, by Craziegurl215
Did you ever fix this problem? I just downloaded it myself and got the same single file (hocus_pocus.exe). I would love to figure out how to run this game since I legitimately bought it!
Thanks =D
Reply 10 of 12, by keropi
I suspect hocus_pocus.exe is just a windows self-extracting archive... the files inside are normal DOS ones, so just get a windows machine to extract and transfer files to DOSbox
Reply 12 of 12, by leileilol
And if legal, it's most likely a rerelease with dosbox included. I think siegler did that before he left apogee
