First post, by retro games 100
Recently, I've been doing some over clocking experiments, using a Coppermine 1 GHz CPU, a Powerleap adapter, and Windows 98. I've discussed this topic here.
I'd like to rerun these tests, but make a screen capture of the results. I think it would look good to have the various test results on the screen at the same time. For example, I could have "Everest Home edition" report the CPU and its speed on one part of the screen, and also have "Sandra 2002 Pro" report its CPU arithmetic results on another part of the screen. I could then make a whole screen capture.
Can some please recommend a (freeware) download for Windows 98, that will allow me to do a screen capture? Thanks a lot people.
Edit: I have included some "carriage return line feed" combos, in order to break up this message, in the hope that it makes it easier to read.
Reply 2 of 8, by Amigaz
PRINT SCREEN --> EDIT -- > PASTE into your favourite image editor (Paint, xnview etc)
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 3 of 8, by retro games 100
Qbix wrote:
here some "enters"
Sorry, I don't understand.
I must be doing something wrong with the "Print Screen" keyboard technique, because I've never seen a screen capture taken using it. Is it CTRL key + PRINT SCREEN key combo? And where does the screen capture image go to please? Thanks.
Reply 4 of 8, by Amigaz
retro games 100 wrote:
Sorry, I don't understand. […]
Qbix wrote:
here some "enters"
When you press PRINT SCREEN the screendump is stored in the windows clipboard, just pressing PRINT SCREEN captures the whole screen.
Then in an image editor you can "collect" th captured screen from the clipboard by just pasting it from the edit menu...then you save the image in which format you want etc
Using ALT + PRINT SCREEN let's you capture an individual window
Reply 5 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
Your story would be much easier to read if you add some enters.
Water flows down the stream
Reply 6 of 8, by retro games 100
Thanks a lot people! All comments taken on board, and stored in the ship's computer.
Reply 7 of 8, by retro games 100
I forgot to say that I can get this done on either Fri or Sat. I can't retest the hardware any sooner, because I'm currently out of town.
Reply 8 of 8, by AlienBZ
Way too supercool, man! I like the way you talk.
