Reply 40 of 54, by Mau1wurf1977
- l33t++
wrote:[…]
3Dbench v1.0 results
Clock | ISA | VLB
25 MHz : 9.8 FPS | 11.4 FPS
33 MHz : 13.1 FPS | 15.3 FPS
40 MHz : 15.8 FPS | 18.5 FPS
Thank you so much!!! 😀
13.1 for a DX-33 was exactly what I estimated. Very good to know... Looks like my table is pretty accurate with the estimated "net speed results".
Regarding ISA vs. VLB (I still can't believe you have a 386 with VLB that's awesome...)
The improvement is actually quite impressive. We are talking around 17% better performance! Just shows that ISA was holding back the 386DX by quite a bit...
