Dos box hard drive
First post, by patddfan
is there a way that I can create a hard drive so I can run windows xp within dosbox? I'm using Dapplegrey for frontend
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you can *barely* run Windows 95 on Dosbox, even worse with later Windows 9x versions. You cannot run Windows XP in Dosbox.
Use Virtualbox instead http://www.virtualbox.org/
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by IIGS_User
Frontend-independent, Windows 3.1 might work, but no later windy version.
Creating hard drives? I believe Bochs includes bximage which should work with.
Klimawandel.
