First post, by zerain
Not sure if my system stats are necessary, given the nature of the problem im having. Dosbox (0.73)with New Horizons Uncharted Waters works beautifully on my laptop.
I have been playing it for the last 2 days almost straight (have strep throat and partially bed ridden) Ive been saving like every half hour, but about an hour ago the game began to slow a little so I exited out and restarted my laptop. When I reloaded the game, all the save files are empty/ I tried closing it and reloading the shortcut, the actual icon, the icon that has the version as part of its name, everything I could think of.
And to make it even a bigger kick in the throat, just to see if it would work, I started a new game, saved and exited. Now every time I reload, that save file is there but none of the original. Will I ever see my precious save files again, or should I just roll over and start a new game/die?
Reply 1 of 1, by eL_PuSHeR
Are you using the same mounting lines? Also, you should update DOSBox to latest version 0.74
