CD check
First post, by Goodmood Selectah
Hello!
I have a problem with Z.A.R. game.
The game needs a CD check to run, which can't be successful through DosBox!
Here's my [autoexec] part of DosBox configuration file.
mount c: F:\ -t cdrom -usecd 0 mount d: C:\Games\ZAR d: zar.exe […]
d:
zar.exe
Am I doing smth wrong, or is it a common problem?
Read several forums, found similar questions but no answers.
Hopefully, I'll get some answers here.
Reply 3 of 16, by DosFreak
Reinstall the game inside DOSBox
Do not mount the game directory as C:\. If you do then the game will be in the root of C:\ when it should be in C:\whatever
Make your games work offline
Reply 4 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Mount the games folder and not the zar folder and cd to that.
Also please use an image uploader that doesn't switch to porn sites.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 16, by Goodmood Selectah
Did successfully reinstall the game using DosBox from CD.
Changed configuration file:
mount d: F:\ -t cdrom -usecd 0 mount c: C:\Games c: cd zar zar.exe […]
mount c: C:\Games
c:
cd zar
zar.exe
Still have the same problem.
Reply 6 of 16, by Gamecollector
Tested with my own "Z.A.R." cd. All is working perfectly.
Reply 8 of 16, by Dominus
DOSBox Moderator
😀 I do too, but I was on a mobile device...
Reply 10 of 16, by Gamecollector
DOSBox 0.74.
Z:>mount c E:\dosbox -freesize 500
Z:>mount d j:\ -t cdrom
Z:>d:
D:>install.bat
C:\ZAR>go.bat
Later:
Z:>mount c e:\dosbox -freesize 500
Z:>c:
C:>cd zar
C:\ZAR>go
Reply 14 of 16, by Gamecollector
Test your cd with attached sfv.
Also the cd have 13 CDA tracks.
    zar.7z
    3.52 KiB
    205 downloads
    Z.A.R. cd sfv
