First post, by smon696
Hello!
I got the latest DosBox version and got myself a version of Air Power in a directory. Mounted it, but when I tried to start it I always get the message:
"Error DISKIO :The graphics library for the selected resolution was not found. Before trying SVGA for the first time please run SVGAtest"
But using "machine = vgaonly" or editing the config-file didn't bring any change.
Hope you can help me.
greetings
SMon
Reply 1 of 8, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Change machine back to its original value and do what the program tells you.
1+1=10
Reply 2 of 8, by smon696
Thanks for your response, but the default S3 seems not to be listed in in svgatest
Reply 3 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It's written very plainly on the SVGATEST card selection screen to choose "Other" if your card is not specifically listed.
That said, the SVGA setup is rather... tedious... at least for the "Other" option. Alternatively you could try machine=svga_et4000 and select that card type in the test program, but not sure if that will spare you the setup tedium.
Reply 4 of 8, by rcblanke
Using the et4000 setting makes the game fail to enter graphics mode at all (music begins to play and screen text colors change, but no graphics).
Reply 5 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Seems to works fine here when loading an appropriate VESA driver for ET4000. I guess it's a bit strange to select the card type and then require VESA anyway, but at least you don't have to go through all the test/calibration stuff.
Reply 6 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Works for me with machine=svga_s3, choosing "Other" in SVGATEST, and going through the tests. Also works for me with machine=svga_et4000, loading TLIVESA.COM, choosing "ET4000" in SVGATEST.
Choosing the SVGA type in the install program seems to have problems. You need to mount an A: drive for some reason or the installer can crash DOSBox with an exception; and then the chosen SVGA driver doesn't seem to work. Anyway, I suggest using SVGATEST for choosing the SVGA type, and the installer for changing sound options.
Reply 7 of 8, by rcblanke
Ah, indeed, thanks for the hint ripsaw. The trick here (after loading TLVESA.COM/TLIVESA.COM) is that the installer suggests a ET4000 driver, which does not work properly (blinking screen). Using the 'Standard' driver works perfectly fine though.
Reply 8 of 8, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
