First post, by Mayiko
I am running DosBox 0.74. I am trying to get Wing Commander 2 running. I have read that I should use the LoadFix command. The problem is that whenever I use this command the program does not load. All I see is that memory was allocated, and then memory was freed. I put this under general because I am not sure if this is specific to the game, or if it is a DosBox problem.
Thanks for the help.
