Daggerfall
First post, by Forte58
Hey guys. I mounted everything correctly and have the daggerfall game stuff. I did the install, then when it prompts me to start i type DAGGEr as said, it says "You have entered the wrong CD. Insert The DAGGERFALL cd and try again"Please help guys, i really want to play this game!
Bonjour~!
Reply 1 of 7, by keropi
first of all, did you get your copy from here -> http://www.elderscrolls.com/daggerfall/ ??
Reply 2 of 7, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Reply 4 of 7, by Freddo
That error message is rather common when the user mounted the CD-ROM wrongly, but since you say you mounted everything correctly that can't be it so don't bother to double-check that.
Reply 5 of 7, by Forte58
Im pretty sure, i mounted the drives correctly and did the install files,
Bonjour~!
Reply 6 of 7, by Forte58
And yes it was from the Elder Scrolls website,
Bonjour~!
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
You probably didn't mount the cdrom correctly after all. Why not share how you did it ?
Water flows down the stream
