First post, by kataniel
Hello, I have a problem with my ESS1868F soundcard and hope you can help.
During bootup, it is configured via esscfg.exe to IRQ 5.
When I start windows (drivers for the card are installed) and return to DOS, the config has changed. It uses IRQ11 now and an other DMA etc.
I would rather use a NON-PNP card like an SB16, but because of the hanging notes bug in conjunction with a DB50XG, I switched to the already mentioned ESS1868F card.
I hope somebody can help.
I would also appreciate suggestions for a good non-PNP card without the hanging notes bug.
kataniel
