First post, by Gamecollector
- Oldbie
Machine=svga_s3, fullresolution=original, output=ddraw, aspect=true.
All 200/400 lines modes are having the black area on the bottom.
Bug in the aspect correction algoritm?
Seems so... I was able to reproduce this; with aspect=true 640x400 seems to render as 640x467 or so.
try Megabuild 6 - it uses a different algorithm for aspect correction which fixes this (and other) issues. I believe hal wrote that he was going to merge those changes into SVN at some point.
Well, I can simply use SDD 5.3a - this way only the 640x350x16 is affected. (Strange, 640x350x16, 640x400x16 and 640x480x16 modes are using double resolution - 1280x960, not the original...)
