First post, by PortsmouthBiker
Bit of a bizarre issue, I've checked the forum and found nothing that comes close.
First a big congrats for getting Blood to work, I tried a Virtual PC using win98 and that run very badly indeed (and even then, had to be in DOS mode, with low resolution), and sound is terrible.
On Dosbox, Blood works almost flawlessly. Controls, graphics, sound, you name it, it's as good as the good old days when I tried this new-fangled Win95 😀
But, problem is, it repeats levels. I played E1M1, went to E1M2, then E1M3, and that looped back to E1M2. Kinda frustrating, you get nowhere! Obviously you can cheat and warp the levels, but then you lose your items. Yes you can cheat and get all items, but that loses the progression and gameplay 🙁
I checked the config for blood: yes it's E1M1, E1M2, E1M3, E1M4 etc.
I'm running the latest Dosbox - 0.74 I think.
I'm using a fairly modern laptop, I don't think the specs are partiucularly an issue here, it's a dual core fast laptop with some 4GB memory, like I say, Dosbox works and runs flawlessly - just that repeat level thing.
Checked the forum but found nothing similar, so... any suggestions as to what is going on and how to fix it?
Thanks in advance!
