First post, by RogueTrip2012
- Oldbie
Ok, trying to give Windows ME another shot.
First issue is SoundBlaster Live! and SB16 Emulation in device manager. If I use the CD Live 3.0 ISO and update. All is well until I try to reboot. If I choose to reboot it hangs. Startup and shutdown do not do this. If I disable it in device manager then Reboot functions again. Also tried the SBLIVE2 that is available on MDGX repository and causes even more issues booting with SB16 Emulation.
Second issue. Cannot get Daemon Tools 3.47 to work proper. Off the bat you need to have a newer MS Installer installed. Got the file seperate or use the unofficial SP2 Beta 9 which contains the same. Depending on my luck the computer either hangs at startup and bootlog never shows a fail when going to safe mode. Other times installing it, it may boot but then says "Virtual SCSI driver not detected" in windows and cannot open the program without it saying this. Also nothing shows up in Device manager for SCSI unless in Safemode.
Tried Kernel EX 4.5.2 and no go.
I can't keep count of how many fresh installs I did so far. Maybe 5 now. I have had windows 98SE running on a 120GB IDE with this system so I know it should not be a hardware issue.
System:
Windows me
P!!! 1.4GHz-S
ASUS CUSL2-CB
512MB CL2 Crucial
WD 160GB IDE
16X DVD-ROM IDE
Sony Floppy drive
Voodoo 4 (powercolor evil king IV)
Intel 1000MT NIC
Soundblaster Live!
NEC 4-Port USB 2.0 PCI card
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
