First post, by Fexel
Im using a SVN Daum Build Win95c Dosbox. Works so far.
Now i want to integrate an 8gig hd to my emulated os (as second hd).
In my Autoexe is the following:
imgmount 2 .\images\c.img -size 512,63,16,711 -t hdd -fs none -ide 1m
imgmount d .\images\d.img -size 512,63,255,1023 -t hdd -fs none -ide 2m
boot -l c
IDE Categorie is like this:
[ide, primary]
# enable: Enable IDE interface
# int13fakeio: If set, force IDE state change on certain INT 13h commands.
# IDE registers will be changed as if BIOS had carried out the action.
# If you are running Windows 3.11 or Windows 3.11 Windows for Workgroups
# you must enable this option (and use -reservecyl 1) if you want 32-bit
# disk access to work correctly in DOSBox.
# int13fakev86io: If set, and int13fakeio is set, certain INT 13h commands will
# cause IDE emulation to issue fake CPU I/O traps (GPF) in
# virtual 8086 mode and a fake IRQ signal. you must enable this option
# if you want 32-bit disk access in Windows 95 to work with DOSBox.
enable=true
int13fakeio=false
int13fakev86io=true
[ide, secondary]
enable=true
int13fakeio=false
int13fakev86io=true
[ide, tertiary]
enable=false
int13fakeio=false
int13fakev86io=false
[ide, quaternary]
enable=false
int13fakeio=false
I cant integrate it to the os.. Any Idea?
Reply 2 of 7, by NetPCDoc
Ok - first the disclaimer - I am a newbie to DOSBox ...
BUT - I did a lot of this sort of thing, back in the day, when those big drives first came out and we had to make them work with the then current Operating Systems...
So ... I'm not too sure of how DOSBox is emulating IDE Support?
[history lesson 1990s]
BUT ... on the IDE Systems - standard was two (2) IDE Controllers, a Primary and a Secondary IDE Controller - each capable of controlling a Master and a Slave IDE Drive.
AND ... the IDE design, with special (custom?) cables, allowed for up to 4 actual IDE Drives on each controller - how some systems piggy-backed a backup-tape drive to two hard disk drives.
Then there were the two(?) size restriction factors that had to be overcome ...
... First - the BIOS limit on physical sizes - based on the field size for the cylinders/heads/sectors numbers (around 504 MB?).
LBA - Large Block Area(?) w/int13-patch - replaced "sectors" with "clusters" (where each cluster could have a base-2 factorial of sectors) ---
--- thus the bios thought it was feeding the IDE Controllers secter numbers - which the IDE Controllers were using as cluster numbers.
... 2nd was the FAT16 FS limits on logical sizes (about 2-4 GB) - Partitioning was the workaround - unitl the FAT32 FS was implemented to overcome this limit;
until Microsoft switched their support to only NTFS (about the time WIN-XP was released).
[/history lesson 1990s]
Maybe this gives someone some sort of an idea/clue of what needs to be done?
And - then again - going back over the "autoexec" commands:
- are you really trying to mount an '-fs none' image to a drive letter (d) ? I believe that I read somewhere that a number (ex: 3) is proper for images that don't (yet) have a FS!
... as you have the c.img mounted as master (2) ... the d.img might be mounted as slave (3)? (or maybe 4 - as a second master - might work? Although this doesn't match your IDE example.)
Reply 3 of 7, by Joey_sw
if you use imgmount d, for win95 the "d" images can only contain 1 partition, and can be only up to maximum FAT16 capability for win95 to recognize it.
if you mount a hdd images that contain more than one partitions,
it must be mounted not to drive letter, but to drive number.
-fffuuu
Reply 4 of 7, by Jorpho
If you wish to educate yourself, the details are available around DOSBox-X branch , though the patch in question is currently in development and I'm not sure if the 504 MB barrier has been bypassed already. The subsequent page suggests it might be.
FAT32 support was introduced in Windows 95b; as the OP is running Win95c, it should be able to recognize FAT32 partitions. Mounting to a drive number is probably a good idea for starters.
Standard DOSBox (without IDE emulation) has no FAT32 support and thus has a 2 GB limitation for hard drive images, if I'm not mistaken.
Reply 6 of 7, by DosFreak
I see a email address posted on his webpage. Mabye you should try that.
These forums are for the official version of DOSBox.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 7 of 7, by Jorpho
Fexel wrote:
Im asking for help with the SVN Daum DOSBox (as u can see in the startpost). This Build support 8gig Images!
What, exactly, makes you so sure of that?
So please help me to get it working.
So did you try
imgmount 3 .\images\d.img -size 512,63,255,1023 -t hdd -fs none -ide 1s
