First post, by MaxWar
- Oldbie
Hey what's up guys! Been playing with Master of Orion 2 lately ( bought on GOG ), a great game, having a blast playing it again after all these years.
I was wondering why there is a midi music setting in the setup file. That is considering there is seemingly no midi music whatsoever in the game. All the music is low quality PCM audio ( 22khz 8bit Stereo).
It came to my mind that it might be because the game uses Miles Design Audio Interface which might use a generic SetSound application.
Anyway this prompted me on a quest to see if the game could be modded for better audio. I extracted the music library from the LBX archives used by the game and tried replacing the music files with higher quality files. That does not quite work out of the box. If I try 16 bit PCM, it result in horrible screeching noise. IF I leave 8 bit but use 44 khz, it simply plays twice slower. Seems there is no way around that unless maybe the game could somehow be patched with a fresher version of the sound drivers it uses which might allow higher bit rate audio.
I really do not know much about Miles Design Audio Interface but I though it might be worth a shot to post this here in case someone has an idea. The horrible PCM quality is really the part that did not age so well with this game. Imho
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
