First post, by kanecvr
- Oldbie
It might be some kind of Riva TNT2. I don't remember any other GPU using 16 SDRAM modules.... even TNT2 in this configuration is rare.
Matrox on the top right side seems to be G400 DH. G450 are using different PCB and smaller heatsink.
wrote:It might be some kind of Riva TNT2. I don't remember any other GPU using 16 SDRAM modules.... even TNT2 in this configuration is rare.
That's what I'm thinking... maybe a TNT2 pro ro a Geforce 256 with SDRAM or SGRAM? Never seen a vintage AGP 4x card with that many memory chips before...
wrote:Matrox on the top right side seems to be G400 DH. G450 are using different PCB and smaller heatsink.
Frankly I was hoping it was a G400 MAX...
The Gus clone is a Primax Atrasound Sound M16C also known as the GUS CD3.
GUS Clone = Primax Music Sound
Current Project: new GUS PnP compatible soundcard
[Z?]
It may be a "Primax Soundstorm", I have one shrinkwrapped here, looks the same from the picture. I don't know the differences (if there are any hardware differences) between the Altrasound, the Music Sound and the Soundstorm, but of course "Soundstorm" sounds the coolest 😉 Maybe its just different names for different markets for the same card. Neat that it has the ICS hardware mixer the earlier GUS classics lack. A great card.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
wrote:That's what I'm thinking... maybe a TNT2 pro ro a Geforce 256 with SDRAM or SGRAM? Never seen a vintage AGP 4x card with that many memory chips before...
Yes, GF 256 SDRAM is also possible. SGRAM modules look different, they are more square-like with data pins on all four sides. As far as I know, there are no SDR SGRAM-based GF 256. On the other hand DDR SGRAM is very common for GF 256 DDR and also some GF2 GTS/PRO... but that's definitely not the VGA on your photo.
G400 Max should be using active cooling... so unless someone replaced the heatsink, this card is regular G400.
Does the heatsink on the graphics card have spring clips holding it on? it looks like it from the picture, if it is why not take it off and see if the chip has anything printed on it.
I always check for fcc codes. If they are stamped onto the pcb they might give you a clue what type of card it is.
Alright, I've got a couple for ya...
Any one know this one? Which Sound Blaster is this a clone of? A SB 2.0 or a SB Pro?
I couldn't find a pic on the net of an ESS card that looked like this one so thought it might be a clone. So which model ESS is it or which is it a clone of?
ESS688 is SoundBlaster Pro compatible if I'm not mistaken.
I'm trying to identify the MB in this PC. It has a SiS chipset, definitely a SiS 5595 southbridge. It is a slot 1 with a PIII 450 installed. It has integrated graphics, so I think that means it is a 620/5595, but I'm not 100% sure on the 620.
I can disconnect some cabling if needed, but I think the pictures show enough. The ribbon cables are hiding two ide and one floppy connector as well as two dimm slots in case it isn't clear.
I didn't find any hits on the "6S2M1" silkscreen text.
I appreciate any help!
wrote:I'm trying to identify the MB in this PC. It has a SiS chipset, definitely a SiS 5595 southbridge. It is a slot 1 with a PIII 45 […]
A search brought up Fordlian Red Fox 6S2M1, the chipset is (as you guessed) SiS 620 + SiS 5595. (The maker is Fordlian and the brand is Red Fox.)
Here are the BIOS and manual.
Fantastic. Thanks! I have no idea how I screwed up my google search for 6S2M1 😀
https://www.flickr.com/photos/94839221@N05/14 … 57633216840005/
What is that (beside VGA) ?
Relais indicate either a ADC/DAC capture card or a modem with an unusual connector.
[Z?]
There is no circuit on there for a modem or a capture device. Rather it could be a LCD interface.
Maybe the company could give some info...
About unknown PCI+ VGA cards: Just fire them up and read the PCI ID? Or even more simple, fire up a Lubuntu on a stick and check the system profiler.
1+1=10
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Looks very similar:
http://thinkwiki.de/700
(Found through: http://www.thinkwiki.org/wiki/ThinkPad_History)
1+1=10
wrote:Anyone recognizes this IBM laptop?
This is the only picture and I guess it's around 1992.
How can you not identify a laptop?
wait, is this NOT something you own?
do the Fandango!" - Queen
Stiletto
wrote:How can you not identify a laptop? ... wait, is this NOT something you own? […]
Im guessing this is something he used to own. Not unreasonable of him to ask. Theres an old PIII Gateway with Windows ME i used to own that i would go through hell and highwater to know the model of.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
