PCMCIA Storage
First post, by lolo799
Does the subject really need a thread?
Are there more than Compact Flash to PCMCIA adapters out there?
Do they work in DOS?
The answers to all those questions are Yes it does, there are and most do, so it's totally relevant to our retro file transferring needs!
Let's start at the beginning, here is a picture of the PCMCIA storage devices I own:
The attachment pcmcia-storage.jpg is no longer available
Compact Flash, Microdrive, Iomega Zip, Sony Memory Stick, Flash media, Iomega Clik!, HDD, and an ATA interface card for 2.5" HDD.
I don't own a SD to PCMCIA adapter, so if anyone of you does, please test it, thanks.
The Zip drive has its own DOS driver, all the other cards work under DOS (except for the Clik! drive) using the enablers found at http://www.tssc.de/site/products/enablers/ata … ab/default.aspx
Some benchmarks, using HddSpeed v2.1 under DOS and Roadkil's Disk Speed Version 2.0 under Windows XP,
CBATA/386 Version 3.10 - Release 11-Apr-2003
(C) Copyright 1993-2003 by APSoft
All rights reserved. Disassembly or decompilation prohibited.
Please, specify serial number or press ENTER without any input for run
evaluation version
Detected PC Card '256MB ' in Socket 0:9:0
ATA Drive Information
Serial number : CF00000000
Firmware revision : 041FA
Model number : Flash Card
Number of cylinders : 03E7h
Number of heads : 0010h
Number of sectors per track : 0020h
Number of cur. cylinders : 03E7h
Number of cur. heads : 0010h
Number of cur. sec./track : 0020h
Current capacity in sectors : 0007CE00h
Total number of user addres. sectors : 0007CE00h ( 250 MB - LBA mode only)
Buffer size : 00000200h ( 0 KB)
Current number of sectors per block : 0001h (for multiple commands)
The maximum number of sectors per block: 0001h (for multiple commands)
LBA mode is supported.
Device is magnetic media.
PC Card uses Drive E:
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÝHddSpeed v2.1 ResultsÞÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
þ Hard Disk 1: Unknown Type (Compact Flash adapter)
þ Size:
BIOS: 243 MBytes
þ Geometry:
BIOS: 31 Cylinders, 255 Heads, 63 Sectors
þ Disk Rotation Speed: Not Determined
þ Average Seek Time: Not Determined
þ Track-To-Track Seek Time: Not Determined
þ Average Access Time: Not Determined
Read (MBytes/sec.) Write (MBytes/sec.)
þ Linear Speed At Track 1: 1.3 1.6
þ Linear Speed At Track 29: 1.3 1.6
þ Average Linear Speed: 1.3 1.6
þ Min. Linear Speed: 1.3 1.6
þ Max. Linear Speed: 1.3 1.6
þ Max. Cache Read Speed: 1.4 MBytes/sec. (64K block)
Detected PC Card 'HITACHI FLASH' in Socket 0:9:0
Serial number : X0208 20040616042825
Firmware revision : Rev 3.00
Model number : Hitachi XXM2.3.0
Number of cylinders : 07C3h
Number of sectors per track : 003Fh
Number of cur. cylinders : 07C3h
Number of cur. sec./track : 003Fh
Current capacity in sectors : 001E8FD0h
Total number of user addres. sectors : 001E8FD0h ( 978 MB - LBA mode only)
Buffer size : 00000400h ( 1 KB)
þ Hard Disk 1: Unknown Type (Flash)
þ Size:
BIOS: 977 MBytes
þ Geometry:
BIOS: 993 Cylinders, 32 Heads, 63 Sectors
þ Linear Speed At Track 1: 1.3 1.2
þ Linear Speed At Track 991: 1.3 1.0
þ Average Linear Speed: 1.3 1.2
þ Min. Linear Speed: 1.3 1.0
þ Max. Linear Speed: 1.3 1.2
þ Max. Cache Read Speed: 1.3 MBytes/sec. (64K block)
Detected PC Card 'HITACHI microdrive' in Socket 0:9:0
Serial number : N2JPE19A
Firmware revision : DN4OCA2A
Model number : HMS360404D5CF00
Number of cylinders : 1F00h
Number of cur. cylinders : 1F00h
Current capacity in sectors : 007A1000h
Total number of user addres. sectors : 007A1000h (3906 MB - LBA mode only)
Buffer size : 00020000h ( 128 KB)
Current number of sectors per block : 0000h (for multiple commands)
The maximum number of sectors per block: 0020h (for multiple commands)
PC Card uses Drive F:
þ Hard Disk 1: Unknown Type (Microdrive)
þ Size:
BIOS: 3906 MBytes
þ Geometry:
BIOS: 992 Cylinders, 128 Heads, 63 Sectors
þ Disk Rotation Speed: Not Tested
þ Average Access Time: 20.5 ms
þ Linear Speed At Track 1: 1.6 1.4
þ Linear Speed At Track 990: 1.5 1.2
þ Average Linear Speed: 1.5 1.3
þ Min. Linear Speed: 1.5 1.2
þ Max. Linear Speed: 1.6 1.5
þ Max. Cache Read Speed: 1.6 MBytes/sec. (64K block)
þ Disk Speed Index: 77
FAT HPFS386
þ Weighted Speed Index: 14 5
Detected PC Card 'TOSHIBA MK5002MPL' in Socket 0:9:0
Serial number : 93F21416 T
Firmware revision : V2.10 A
Model number : TOSHIBA MK5002MPL
Number of cylinders : 2896h
Number of heads : 000Fh
Number of cur. cylinders : 2896h
Number of cur. heads : 000Fh
Current capacity in sectors : 0095D1B6h
Total number of user addres. sectors : 0095D1B6h (4795 MB - LBA mode only)
Buffer size : 00035000h ( 212 KB)
Current number of sectors per block : 0010h (for multiple commands)
The maximum number of sectors per block: 0010h (for multiple commands)
Device is non-magnetic media.
þ Hard Disk 1: Unknown Type (PCMCIA HDD)
þ Size:
BIOS: 4792 MBytes
þ Geometry:
BIOS: 611 Cylinders, 255 Heads, 63 Sectors
þ Disk Rotation Speed: 4000 RPM
þ Average Access Time: 21.5 ms
þ Linear Speed At Track 1: 1.6 1.0
þ Linear Speed At Track 609: 1.6 1.0
þ Average Linear Speed: 1.6 1.0
þ Min. Linear Speed: 1.5 0.9
þ Max. Linear Speed: 1.6 1.0
þ Max. Cache Read Speed: Not Determined
þ Disk Speed Index: 74
FAT HPFS386
þ Weighted Speed Index: 12 5
The attachment CF&Flash.jpg is no longer available
The attachment MS&ATA.jpg is no longer available
The attachment Microdrive&HDD.jpg is no longer available
The attachment Zip&Clik.jpg is no longer available
As you can see, the Flash devices are the fastest and the Iomega drives the slowest, nothing surprising at all here!
The Memory Stick adapter is directly supported on the HP 200LX Palmtop computer (atleast with my 8MB card), whereas some Compact Flash cards need a driver to be loaded first which can be problematic to transfer on the unit in the first place...
My obvious advice is to go with the simplest and cheapest, so a no-name Compact Flash adapter and a bunch of CF cards.
Thanks for reading!
Reply 1 of 12, by Bondi
Guess it belongs to this topic. Got this EZ-GIG card today.
It's a very handy way to connect HDDs to old laptops. It has a standard 44 pin IDE connector and can be used to connect any 2.5 IDE drive via PCMCIA port. Tested it in Windows 95 and pure DOS (with standard IBM SC,SS+PCMCIA ATA drivers). Works fine in both.
Originally it came with a DOS bootable diskette, that had HDD cloning/backup software. It basically cloned sector by sector the internal HDD to the one connected to PC Card. Bit it was limited to 10 drives. The diskette was copy protected, and is not available online. Which is sad as it would be a great way to clone/backup HDDs without removing the HDD from the laptop.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 3 of 12, by AshleyPomeroy
Not technically PC related, but Kodak's old digital SLRs used to use PCMCIA storage cards. Here's my DCS 520 with a Callunacard and a 1gb industrial PCMCIA card:
And a pair of PCMCIA/Compact Flash adapters:
The bus was hot-swappable and used FAT32, which was impressive for 1998 or 1999 or so. I believe the cameras ran on PowerPC hardware. I remember trying a PCMCIA-CompactFlash-SD-MicroSD adapter chain, but it didn't work (either the SD-MicroSD adapter or the MicroSD card itself was the culprit). Sadly the Callunacard stopped working after a short while; I have the impression that the shock of using it after however many years in storage killed it.
From what I remember the Amiga 600 had a PCMCIA slot. Didn't take off as removable storage but the form factor found a niche for wifi and USB 2.0 adapters.
Reply 4 of 12, by Pierre32
Here's my parallel port PCMCIA flash reader. I use a CompactFlash adapter in it. It's one of my favourite things ever. There's no easier tool for slinging data between my DOS and 9x machines.
I discovered this family of devices, and the associated DOS drivers thanks to Ozzuneoj's thread. Then I happened to find mine on ebay right afterwards. Parallel Port Compact Flash card reader for very old PCs
Reply 5 of 12, by Bondi
A weird device that I'm not sure whether should be in this thread or in pcmcia sound cards thread. A battery powered PCMCIA voice recorder. I assume that it's combined with some kind of storage, and you get your recordings right on it. NOS for sale on ebay right now.
The attachment pcmcia.jpg is no longer available
Reply 6 of 12, by lolo799
Bondi wrote on 2020-02-19, 16:12:
You could use any other hdd backup/cloning software with this though, you're not limited to the one that came with the card.
AshleyPomeroy wrote on 2020-05-26, 14:27:
The Callunacard is Pcmcia type iii hard drive, no wonder the shock killed it!
Pierre32 wrote on 2020-05-26, 14:37:
You can read regular pcmcia flashcard too, probably sram as well.
And SmartMedia, which was the next big thing in the storage world...
Bondi wrote on 2020-07-06, 14:49:
Probably recognized as standard pcmcia ATA device under Windows.
There was atleast one digital camera that worked like that, with internal flashram storage and an integrated pcmcia interface to plug it in a computer to transfer the pics.
Reply 7 of 12, by Bondi
There is always something new in the PCMCIA zoo.
Not exactly a storage device, but something close to it. An adapter to use Type III HDDs in Type II slot.
The attachment PCMCIA HDD_.png is no longer available
The attachment PCMCIA HDD.png is no longer available
Reply 8 of 12, by lolo799
Bondi wrote on 2022-06-15, 15:31:
Does it have a connector for an external power supply?
Reply 9 of 12, by Bondi
lolo799 wrote on 2022-06-16, 16:01:
I don't think so. It's just a passive adapter to free up one slot. A Type III HDD would occupy both slots otherwise.
Reply 11 of 12, by BitWrangler
Guess it belongs to this topic. Got this EZ-GIG card today. https://i.ibb.co/JHYcsh4/IMG-2014.jpg It's a very handy way to conn […]
I have one of those also. I don't think I have the DOS disk either. Mine came from when my wife's company at the time was closing up an office location so came in with a box of other random tech. However just as I was thinking about it now, I thought that was an early load and I got more random stuff later, it's possible it's disk is in some other stuff still and I hadn't recognised it, so faint chance it will turn up. Didn't really know I should be looking for a disk for it. I thought it was just used through windows. Only seems about ~90% compatible to me, there's drives I've got it won't read, but are fine on a USB adapter. Don't know if that improves with that driver disk. Weirdly they were meant to be basically single use items, just to sell laptop disk upgrades. Plug this in to get your data across.
Reply 12 of 12, by Bondi
lolo799 wrote on 2016-03-27, 12:00:
I have this Panasonic SD-PCMCIA (model no BN-SDAAP3) adapter and it works in DOS. It’s seen as a standard ATA storage device. Tried cards up to 2 gigs with no issues.
The attachment sdpcc.jpg is no longer available
