Finished, Finally!
First post, by rick12373
I am please to report that I have finally finished my 486 build. This was inspired by LGR's video that he posted back in July https://www.youtube.com/watch?v=fbjYkPKRm-8 . It took me until now to gather the parts necessary and then figure out how to put it together. I am using the same motherboard as LGR as that seemed like a great choice. I ended up putting a DX4 100 overdrive and a GoTek Floppy Emulator in it as well. I initially wasted a lot of time trying to get an old ATX case to work with it but eventually caved and got an AT case from eBay. I am very happy with the case it almost looks new. Anyway, I have posted a few threads on here since starting this endeavour and I appreciate all the help that I received. I realize some of me questions were really noob! Here are a few pictures:
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 22, by bbhaag
Looks great man! I like the case as well it has that nice retro flair too it. Looks like it has decent cable management too considering that wasn't a real concern back then. Congrats again on getting your build together it looks really nice.
Reply 2 of 22, by TheMobRules
Nice! That board has a pretty good chipset for the 486 era, I think a DX4 fits like a glove! More importantly, no barrel or Dallas RTC junk! I have that same board and I'm planning a build around it in the following weeks/months if I can find enough free time.
I see you have a CPU fan there, was the DX4 overdrive running too hot? Because I believe those came with heatsink only, no fan.
Also, I really like the case, did the cool 486 badge come with it or you got it separately?
Reply 3 of 22, by Brickpad
Those Enlight cases are really sharp, and have a nice build quality to them. The removable motherboard tray and tool-less bezel are a nice added touch too.
Reply 4 of 22, by ElementalChaos
My P233 build has the same case with a Myoda badge (local computer dealer which is somehow still in operation with an appropriately gaudy website.) I wish I could find another, it's a tiny little beast and very easy to work with.
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 5 of 22, by 386SX
Nice build! There's space for a faster video card. 😁
Reply 6 of 22, by rick12373
The case badge I got from eBay. I put the fan on the overdrive just because I could really. There is also a case fan at the front. Not really necessary but maybe it will help this old hardware last longer. I am a sucker for cable management, it is an obsession of mine!
SB 16 Value CT2770
Reply 7 of 22, by chinny22
I'm confused
The Pic shows a HDD, you running both a HDD and SD?
You also say your running on board ESS 688, but the pic shows a Sound card, or is that the ESS?
Nice system either way. I'm no purest and also like having the mix of new (gotek/SD's) with old 486's
Reply 8 of 22, by rick12373
I have not updated my signature. That is my other machine.
SB 16 Value CT2770
Reply 9 of 22, by chinny22
So it is! a Compaq Presario CDS 520 by chance? (I just saw 486... and read down from there)
So what's the full spec of this PC?
Reply 10 of 22, by rick12373
The spec of the new one is as follows:
486 DX4-100 (Overdrive)
Soundblaster 16 Value CT2770
HDD is some random IDE drive made within the last 10 years (can't remember)
It is the same motherboard and video card that LGR used in his build here: https://www.youtube.com/watch?v=fbjYkPKRm-8
His video was my original inspiration.
SB 16 Value CT2770
Reply 11 of 22, by rick12373
Well it's been over 6 months since I put this together. I have not had a good chance to enjoy it much yet due to moving and being busy with work. As I have a serial to PS/2 adapter coming soon I thought I would try and figure out the issue with the Soundblaster 16 CT2770 I am having. The volume is really low in all games. The volume is OK in the diagnose utility. When I run the SB16SET.EXE command it comes back with "MIX0014: Low level driver error". Anybody know what that means?
SB 16 Value CT2770
Reply 12 of 22, by Imperious
SET SOUND=C:\YOURPATH\SB16
SET BLASTER=A220 I7 D1 H5 T6 (or i5 for the irq)
REM C:\DRIVERS\SB16\DIAGNOSE /S
C:\YOURPATH\SB16\SB16SET /Q /SP:70
REM C:\YOURPATH\SB16\SBFMDRV
I used the CT2770 with similar settings in an XT 8088 machine, except in that case used H1 T3 due to lack of 16 bit ISA slot, try the above and
see how you go.
Reply 14 of 22, by rick12373
Imperious wrote:
SET SOUND=C:\YOURPATH\SB16 SET BLASTER=A220 I7 D1 H5 T6 (or i5 for the irq) REM C:\DRIVERS\SB16\DIAGNOSE /S C:\YOURPATH\SB16\ […]
see how you go.
I will try this when I get home. I see you REM'd a couple of lines in there. I know I have the one with DIAGNOSE in it, not sure about the SBFMDRV one. But as they are removed that should be OK anyway. If it doesn't work I will post my startup files.
SB 16 Value CT2770
Reply 15 of 22, by rick12373
I tried following your instructions and got the same error while the startup files were being processed. It doesn't help that I have not worked on this for about 6 months. See my AUTOEXEC.BAT and CONFIG.SYS below, maybe you can figure out what I am doing wrong:
AUTOEXEC.BAT:
@ECHO OFF
PROMPT $p$g
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH:1 MAP:E
REM C:\SB16\DIAGNOSE /S
C:\SB16\SB16SET /Q /SP:70
PATH C:\DOS
SET TEMP=C:\DOS
GoTo %config%
:EMC
:XMC
:CMC
LH C:\DOS\MSCDEX.EXE /D:OPTICAL
:EM
:XM
:CM
LH C:\DRIVERS\CTMOUSE.EXE /R2
:E
:X
:C
CONFIG.SYS:
[COMMON]
REM THE FOLLOWING 2 LINES ARE NOT NEEDED BY 99% OF GAMES
REM DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5
REM DEVICE=C:\SB16\DRV\CTMMSYS.SYS
FILES=40
DOS=HIGH,UMB
REM ** FILES=30
BUFFERS=30
LASTDRIVE=H
[menu]
menuitem=EMC, Expanded memory + Mouse + CD-ROM
menuitem=XMC, Extended memory + Mouse + CD-ROM
menuitem=CMC, Conventional Memory only + Mouse + CD-ROM
menuitem=EM, Expanded memory + Mouse
menuitem=XM, Extended memory + Mouse
menuitem=CM, Conventional memory only + Mouse
menuitem=E, Expanded memory
menuitem=X, Extended memory
menuitem=C, Conventional memory only
menudefault=EMC,10
[EMC]
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[XMC]
[CMC]
[EM]
[XM]
[CM]
[E]
[X]
[C]
SB 16 Value CT2770
Reply 16 of 22, by MCGA
Maybe this thread will help:
Issues with an AWE32?
There's a newer(other) mixerset you can download that might fix your problem.
Reply 17 of 22, by 8bitbubsy
Very nice. That silver 486 badge is rockin'!
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates, 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0
- ISA PS/2 mouse card + ISA USB-stick card
- MR BIOS v1.65
Reply 18 of 22, by rick12373
eBay helped with that! 😎
SB 16 Value CT2770
Reply 19 of 22, by rick12373
I will give it a try. I do have another sound card, a Sound Blaster AWE32 CT3780 ISA. If I keep having problems with this SB16 I will switch to that.
SB 16 Value CT2770
