First post, by enloop
Alright so here's the deal. I'm not too sure how to interpret the CPU-Z results because of the stock frequency under processors information. It says 700MHz- what do they mean by that? I ask because everything else seems to be pointing to 850MHz. I looked up similar CPUs and I think I narrowed it down to 2:
The model of this laptop is NEC Versa LXi
Mainboard model: [VP4JBEF-00B-000] - Strange enough this one is not listed anywhere on a website from what I can find.
My other question is about:
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 256 MBytes
max# of devices 2
Is the "max capacity 256MBytes" referring to the limit PER device? Therefore allowing it to reach 512MB? Because I have tried to upgrade the RAM before but I might have just used incompatible memory. The documentation does mention going up to 512MB but I lost my confidence so hearing a 2nd opinion or some assurance would be nice. Probably will be sticking to OEM recommended accessories now.
I'll be damned if I posted in the wrong topic/thread .__. Maybe I can also get some pointers on what to do before trying to overclock this thing? I know I asked a lot but yeah any help/discussion would be appreciated. And I know I should just open the !$%#er but lets save that for later if and when there's desperation..
CPU-Z
Binaries
CPU-Z version 1.57
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Pentium III E
Codename Coppermine
Specification
Package (platform ID) MMC (0x3)
CPUID 6.8.6
Extended CPUID 6.8
Brand ID 2
Core Stepping cC0
Technology 0.18 um
Core Speed 698.2 MHz
Multiplier x FSB 7.0 x 99.7 MHz
Stock frequency 700 MHz
Instructions sets MMX, SSE
L1 Data cache 16 KBytes, 4-way set associative, 32-byte line size
L1 Instruction cache 16 KBytes, 4-way set associative, 32-byte line size
L2 cache 256 KBytes, 8-way set associative, 32-byte line size
FID/VID Control no
Chipset
Northbridge Intel i440BX/ZX rev. C1
Graphic Interface AGP
AGP Revision 1.0
AGP Transfer Rate 2x
AGP SBA supported, not enabled
Memory Type SDRAM
Memory Size 256 MBytes
Memory Frequency 99.7 MHz (1:1)
CAS# latency (CL) 3.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
DRAM Idle Timer 32
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type SDRAM
Manufacturer (ID) Hyundai Electronics (ADFFFFFFFFFFFFFF)
Size 128 MBytes
Max bandwidth PC100 (100 MHz)
Show last 345 lines
     Part number 71V65M1601TX-10S
Serial number 0301813D
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.0-2-2-5-n.a. @ 83 MHz
JEDEC #2 3.0-2-2-5-n.a. @ 100 MHz
Monitoring
Mainboard Model VP4JBEF-00B-000 (0x0000037D - 0xB4C850C0)
LPCIO
Hardware Monitors
Hardware monitor Battery
Voltage 0 8.04 Volts [0x1F68] (Current Voltage)
Capacity 0 64896 mWh [0xFD80] (Designed Capacity)
Capacity 1 5400 mWh [0x1518] (Full Charge Capacity)
Capacity 2 n.a. [0x0] (Current Capacity)
Level 0 92 pc [0x8] (Wear Level)
Level 1 n.a. [0x0] (Charge Level)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x7190
Revision ID 0x03
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x7191
Revision ID 0x03
Description PCI to CardBus Bridge
Location bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x104C
Model ID 0xAC1B
Revision ID 0x03
Location bus 0 (0x00), device 3 (0x03), function 1 (0x01)
Common header
Vendor ID 0x104C
Model ID 0xAC1B
Revision ID 0x03
Description Audio device
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x125D
Model ID 0x1978
Revision ID 0x10
Description Ethernet Controller
Location bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1229
Revision ID 0x09
Description Serial 16550 Controller
Location bus 0 (0x00), device 5 (0x05), function 1 (0x01)
Common header
Vendor ID 0x115D
Model ID 0x002B
Revision ID 0x00
Description Bridge device
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x7110
Revision ID 0x02
Description IDE Controller
Location bus 0 (0x00), device 7 (0x07), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x7111
Revision ID 0x01
Description USB Controller (UHCI)
Location bus 0 (0x00), device 7 (0x07), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x7112
Revision ID 0x01
Location bus 0 (0x00), device 7 (0x07), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x7113
Revision ID 0x03
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x5333
Model ID 0x8C12
Revision ID 0x13
DMI
DMI BIOS
vendor NEC
version BIOS Revision /147A1100
date 04/05/2001
DMI System Information
manufacturer NEC COMPUTERS INC.
product VP4JBEF-00B-000
version PRODUCTION
serial 1XDC00376
UUID {00000000-0000-0000-0000-000000000000}
DMI Baseboard
vendor NEC COMPUTERS INC.
model VP4JBEF-00B-000
revision PRODUCTION
serial 1XDC00376
DMI System Enclosure
chassis type Notebook
chassis serial 1XDC00376
DMI Processor
manufacturer Intel Corporation
model Mobile Pentium(R) III
clock speed 850.0 MHz
FSB speed 100.0 MHz
multiplier 8.5x
usage System Memory
correction None
max# of devices 2
usage Flash Memory
correction None
max capacity 0 MBytes
max# of devices 1
usage Video Memory
correction None
max capacity 16 MBytes
max# of devices 3
DMI Memory Device
designation Memory Slot1
format DIMM
type DRAM
total width 64 bits
data width 64 bits
size 128 MBytes
DMI Memory Device
designation Memory Slot2
format DIMM
type DRAM
total width 64 bits
data width 64 bits
size 128 MBytes
DMI Memory Device
designation 7H2
format TSOP
type FLASH
total width 8 bits
data width 8 bits
size 0 MBytes
DMI Memory Device
designation 1G
format unknown
type SGRAM
total width 64 bits
data width 64 bits
size 8 MBytes
DMI Memory Device
designation 2C
format unknown
type SGRAM
total width 32 bits
data width 32 bits
size 4 MBytes
DMI Memory Device
designation 2B
format unknown
type SGRAM
total width 32 bits
data width 32 bits
size 4 MBytes
DMI Memory Controller
correction unknown
Max module size 128 MBytes
DMI Memory Module
size 128 MBytes (double bank)
DMI Memory Module
DMI Port Connector
designation NULL (internal)
designation Line In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Keyboard/Mouse (external)
connector PS/2
DMI Port Connector
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation Mic In (external)
DMI Port Connector
designation Head Phone/Line Out (external)
DMI Port Connector
designation Serial Port (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation Infrared Device (external)
connector Infrared
DMI Port Connector
designation Parallel port (external)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Monitor (external)
port type Video Port
connector DB-15 female
DMI Port Connector
designation TV-OUT/C-Video (external)
DMI Port Connector
designation TV-OUT/S-Video (external)
connector Mini DIN
DMI Port Connector
designation Telephone Line (external)
port type Modem Port
connector RJ-11
DMI Port Connector
designation Network (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation Versa Bay3 (external)
DMI Port Connector
designation Versa Dock (external)
connector Proprietary
DMI Extension Slot
designation Socket 1
type PCMCIA
width 32 bits
DMI Extension Slot
designation Socket 2
type PCMCIA
width 32 bits
Graphics
Number of adapters 1
Graphic APIs
Display Adapters
Display adapter 0
Name S3 Inc. Savage/IX w/MV
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x5333 (0x1033)
Model ID 0x8C12 (0x80BA)
Performance Level 0
Software
Windows Version Microsoft Windows 98 SE
DirectX Version 9.0b
file.php?mode=view&id=33121&sid=73765dd2309cbcda24136ea2a721c9af
And here is the DirectX information:
System Information
Time of this report: 3/5/2017, 23:30:05
Machine name: *************
Operating System: Windows 98 (4.10, Build 2222) A
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: n/a
Processor: Intel Pentium III, ~850MHz
Memory: 256MB RAM
Page File: 68MB used, 1723MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 4.09.0000.0902 32bit
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file s3_7.drv is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). Current drivers tested for a WHQL logo are only available on Windows ME, Windows 2000, and Windows XP. New Windows 98 drivers are no longer tested for WHQL logos.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: S3 Inc. Savage/IX w/MV
Manufacturer: S3
Chip type: Rev E
DAC type: Internal
Device Key: Enum\PCI\VEN_5333&DEV_8C12&SUBSYS_80BA1033&REV_13\000800
Display Memory: 15.5 MB
Current Mode: 1024 x 768 (16 bit)(optimal refresh rate)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: s3_7.drv
Driver Version: 4.12.0001.7009 (English)
DDI Version: 7
Driver Attributes: Beta Retail
Driver Date/Size: 4/25/2000 04:24:48, 197200 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: *vdd,*vflatd
Mini VDD: s3vdd7.vxd
Show last 479 lines
    Mini VDD Date: , 0 bytes
Device Identifier: {D7B75DD3-CF52-11CF-E268-BBA0B0C2C935}
Vendor ID: 0x5333
Device ID: 0x8C12
SubSys ID: 0x80BA1033
Revision ID: 0x0013
Revision ID: 0x0013
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: ESS Maestro
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_125D&DEV_1978&SUBSYS_80711033&REV_10\BUS_00&DEV_04&FUNC_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: maestro.sys
Driver Version: 5.12.0001.2037 (English)
Driver Attributes: Final Retail
WHQL Logo'd: Yes
Date and Size: 4/4/2000 15:27:16, 139351 bytes
Other Files: maestro.sys
Driver Provider: ESS Technology, Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x40
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\system32\drivers\gm.dls
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
ESS Maestro, Software (Kernel Mode), Output, DLS, Internal
MIDI Mapper, Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU401, Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth, Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU401, Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: Yes
Registry: OK
USB Devices
Gameport Devices
PS/2 Devices
DirectPlay Service Providers
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 IPX Service Provider: Local IPX Adapter
DirectPlay8 TCP/IP Service Provider: Intel(R) PRO PCI Adapter -
DirectPlay8 Modem Service Provider: Xircom MPCI+ Modem 56 WinGlobal
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Deathtrap Dungeon (DX7) - Registry: OK, ExeFile: ddstart.exe ()
DirectX Components
ddraw.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 384000 bytes
ddraw16.dll: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 28496 bytes
ddrawex.dll: 4.87.0000.0700 English Final Retail 9/9/1999 07:00:00 24092 bytes
ddraw.vxd: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 30469 bytes
ddhelp.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dxapi.sys: 4.87.0000.0700 English Final Retail 9/9/1999 07:00:00 2170 bytes
d3d8.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 1208320 bytes
d3d9.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1648640 bytes
d3dim.dll: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 625690 bytes
d3dim700.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 892416 bytes
d3dramp.dll: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 589852 bytes
d3drm.dll: 4.06.0002.0436 English Final Retail 4/23/1999 22:22:00 446464 bytes
d3dxof.dll: 4.06.0002.0436 English Final Retail 4/23/1999 22:22:00 118784 bytes
d3dpmesh.dll: 4.06.0002.0436 English Final Retail 4/23/1999 22:22:00 102400 bytes
dplay.dll: 4.03.0000.1096 English Final Retail 4/23/1999 22:22:00 57344 bytes
dplayx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 229376 bytes
dpmodemx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 90112 bytes
dpwsock.dll: 4.03.0000.1096 English Final Retail 4/23/1999 22:22:00 40960 bytes
dpwsockx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 86016 bytes
dplaysvr.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 40960 bytes
dpnsvr.exe: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 28672 bytes
dpnet.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 720896 bytes
dpnlobby.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 16384 bytes
dpnaddr.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 16384 bytes
dpvoice.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 385024 bytes
dpvsetup.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 86016 bytes
dpvvox.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 122880 bytes
dpvacm.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dpnhpast.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 45056 bytes
dpnhupnp.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 73728 bytes
dpserial.dll: 4.03.0000.1096 English Final Retail 4/23/1999 22:22:00 49152 bytes
dinput.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 667648 bytes
dinput8.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 692224 bytes
dinput.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 10874 bytes
dimap.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 94208 bytes
diactfrm.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 466944 bytes
vjoyd.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 33882 bytes
joyhid.vxd: 4.88.0001.0881 English Final Retail 12/12/2002 00:14:32 13067 bytes
joy.cpl: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 442368 bytes
gcdef.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 491520 bytes
gchand.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 6656 bytes
pid.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 40960 bytes
gameenum.sys: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 10512 bytes
hidgame.sys: 4.07.0000.0700 English Final Retail 11/27/1999 07:00:00 8880 bytes
msanalog.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 12745 bytes
msjstick.drv: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 2352 bytes
dsound.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 475648 bytes
dsound3d.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 1331200 bytes
dsound.vxd: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 47664 bytes
dswave.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 17920 bytes
dsdmo.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 489984 bytes
dmusic.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 114688 bytes
dmusic16.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 10992 bytes
dmusic32.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 28672 bytes
dmband.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 26624 bytes
dmcompos.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 57856 bytes
dmime.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 171008 bytes
dmloader.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dmstyle.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 98304 bytes
dmsynth.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 100352 bytes
dmscript.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 76288 bytes
dx7vb.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 602112 bytes
dx8vb.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1638400 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 4/23/1999 22:22:00 933888 bytes
mfc42.dll: 6.00.8447.0000 English Beta Retail 4/23/1999 22:22:00 995383 bytes
wsock32.dll: 4.10.0000.1998 English Final Retail 10/17/2007 15:01:20 40960 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 65024 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 134656 bytes
dxmasf.dll: 6.04.0007.1119 English Final Retail 6/5/2001 15:27:20 498448 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 8/17/1998 04:21:54 11776 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 135168 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 12800 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 173056 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 311808 bytes
qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 445952 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1795584 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1845248 bytes
quartz.vxd: 4.00.0000.0501 English Final Retail 8/17/1998 04:21:56 5672 bytes
strmdll.dll: 4.01.0000.3925 English Final Retail 4/20/2001 13:14:22 251904 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 8/17/1998 04:21:56 10240 bytes
iac25_32.ax: 2.00.0005.0050 English Final Retail 4/23/1999 22:22:00 198656 bytes
ir41_32.ax: 4.31.0016.0002 English Final Retail 4/23/1999 22:22:00 857600 bytes
ir41_qc.dll: 0.00.0000.0000 English Final Retail 4/23/1999 22:22:00 135168 bytes
ir41_qcx.dll: 0.00.0000.0000 English Final Retail 4/23/1999 22:22:00 352256 bytes
ir50_32.dll: 5.1026.0015.0041 English Final Retail 4/23/1999 22:22:00 753664 bytes
ir50_qc.dll: 5.00.0063.0038 English Final Retail 4/23/1999 22:22:00 212992 bytes
ir50_qcx.dll: 5.00.0064.0038 English Final Retail 4/23/1999 22:22:00 196608 bytes
ivfsrc.ax: 5.03.0002.0038 English Final Retail 4/23/1999 22:22:00 139264 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324608 bytes
ks.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 126464 bytes
ksproxy.ax: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 117760 bytes
ksuser.dll: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 46080 bytes
mspclock.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mskssrv.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:36 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:36 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:42 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:50 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:52 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:38 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:40 56832 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:48 8448 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:40 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:54 14464 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:44 481792 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:54 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:48 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:36 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:54 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:46 16896 bytes
kstvtune.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:15:04 274432 bytes
ksxbar.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:40 39936 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:15:04 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:56 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:56 47104 bytes
msdv.sys: 4.10.2326.0900 English Final Retail 2/17/2003 09:14:42 56832 bytes
Inactive Display Entries in Registry
Card name:
Inactive Sound Entries in Registry
None
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00600800,1,1,,
MSScreen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Indeo® video 5.04 Decompression Filter,0x00640000,1,1,IR50_32.DLL,5.1026.0015.0041
Indeo® video 5.04 Compression Filter,0x00200000,1,1,IR50_32.DLL,5.1026.0015.0041
Indeo(R) audio software,0x00500000,1,1,IAC25_32.AX,2.00.0005.0050
IVF source filter,0x00600000,0,1,IVFSRC.AX,5.03.0002.0038
ClearVideo® Decompression Filter,0x00800000,1,1,CLRAMD.AX,2.00.0000.0001
VIVO Audio Decoder Filter,0x00800002,1,1,VVAUDFLT.AX,3.00.0000.0001
VIVO Video Decoder Filter,0x00600001,1,1,VVVIDFLT.AX,3.00.0000.0000
Lyric Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,ACELPDEC.AX,1.04.0000.0000
WMP CD Filter,0x00600000,0,1,WMPCD.DLL,7.01.0000.3055
Microsoft Screen Video Decompressor,0x00800000,1,1,MSSCDS32.AX,7.01.0000.3055
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,MPG4DS32.AX,7.01.0000.3055
Windows Media Video Decoder,0x00800000,1,1,WMVDS32.AX,7.01.0000.3055
Windows Media Video Decoder,0x00800000,1,1,WMV8DS32.AX,8.00.0000.0371
Windows Media Audio Decoder,0x00800001,1,1,MSADDS32.AX,7.00.0000.1954
WM ASF Reader,0x00400000,0,0,QASF.DLL,6.05.0001.0900
WM ASF Writer,0x00400000,0,0,QASF.DLL,6.05.0001.0900
SampleGrabber,0x00200000,1,1,QEDIT.DLL,6.05.0001.0900
Null Renderer,0x00200000,1,0,QEDIT.DLL,6.05.0001.0900
MPEG Layer-3 Decoder,0x00810000,1,1,L3CODECX.AX,1.05.0000.0050
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PSISRNDR.AX,6.05.0001.0900
VBI Surface Allocator,0x00600000,1,1,VBISURF.AX,5.03.0000.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,MPEG2DATA.AX,6.05.0001.0900
WST Decoder,0x00600000,1,1,WSTDECOD.DLL,5.03.0000.0900
AVI/WAV File Source,0x00400000,0,2,QUARTZ.DLL,6.05.0001.0902
AVI Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
AVI Draw,0x00600064,9,1,QUARTZ.DLL,6.05.0001.0902
Color Space Converter,0x00400001,1,1,QUARTZ.DLL,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
Full Screen Renderer,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Video Renderer,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
Video Mixing Renderer 9,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Video Decoder,0x40000001,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG-I Stream Splitter,0x00600000,1,2,QUARTZ.DLL,6.05.0001.0902
File Source (Async.),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
QT Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
AVI Splitter,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
Wave Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
ACM Wrapper,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
MIDI Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
Internal Script Command Renderer,0x00800001,1,0,QUARTZ.DLL,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
File stream renderer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
File Source (URL),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902
MJPEG Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
Line 21 Decoder 2,0x00600002,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG-2 Demultiplexer,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900
MPEG-2 Splitter,0x005fffff,1,0,MPG2SPLT.AX,6.05.0001.0900
AC3 Parser Filter,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900
Cutlist File Source,0x00200000,0,1,QCUT.DLL,6.01.0005.0217
DV Video Decoder,0x00800000,1,1,QDV.DLL,6.05.0001.0900
DV Muxer,0x00400000,0,0,QDV.DLL,6.05.0001.0900
DV Splitter,0x00600000,1,2,QDV.DLL,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,QDVD.DLL,6.05.0001.0902
Overlay Mixer2,0x00400000,1,1,QDVD.DLL,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,QDVD.DLL,6.05.0001.0902
DVD Navigator,0x00200000,0,2,QDVD.DLL,6.05.0001.0902
AVI Mux,0x00200000,1,0,QCAP.DLL,6.05.0001.0900
File writer,0x00200000,1,0,QCAP.DLL,6.05.0001.0900
Infinite Pin Tee Filter,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Smart Tee,0x00200000,1,2,QCAP.DLL,6.05.0001.0900
Windows Media source filter,0x00600000,0,2,DXMASF.DLL,6.04.0007.1119
ASF DIB Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASF ACM Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASF ICM Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASF URL Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASF JPEG Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASF DJPEG Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASF embedded stuff Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASX file Parser,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
ASX v.2 file Parser,0x00600000,1,0,DXMASF.DLL,6.04.0007.1119
XML Playlist,0x00400000,1,0,DXMASF.DLL,6.04.0007.1119
.RAM file Parser,0x00600000,1,0,DXMASF.DLL,6.04.0007.1119
NSC file Parser,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
Windows Media Multiplexer,0x00600000,1,1,DXMASF.DLL,6.04.0007.1119
File Source (Netshow URL),0x00400000,0,1,DXMASF.DLL,6.04.0007.1119
Windows Media Update Filter,0x00400000,1,0,DXMASF.DLL,6.04.0007.1119
TrueMotion 2.0 Decompressor,0x00600001,1,1,TM20DEC.AX,2.00.0006.0003
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.DLL,6.01.0005.0124
URL StreamRenderer,0x00600000,1,0,LMRTREND.DLL,6.01.0005.0124
Indeo® video 4.3 Decompression Filter,0x00640000,1,1,IR41_32.AX,4.31.0016.0002
Indeo® video 4.3 Compression Filter,0x00200000,1,1,IR41_32.AX,4.31.0016.0002
Voxware MetaSound Audio Decoder,0x00999999,1,1,VOXMSDEC.AX,1.00.0000.0012
Voxware MetaVoice Audio Decoder,0x00999998,1,1,VOXMVDEC.AX,1.00.0000.0011
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,QDV.DLL,6.05.0001.0900
Indeo® video 5.04 Compression Filter,0x00100000,1,1,IR50_32.DLL,5.1026.0015.0041
MJPEG Compressor,0x00200000,0,0,QUARTZ.DLL,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Audio Capture Sources:
ESS Maestro,0x00200000,0,0,QCAP.DLL,6.05.0001.0900
Audio Compressors:
WMAudio Encoder DMO,0x00600800,1,1,,
PCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
GSM 6.10,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
ACELP.net,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Voxware MetaSound,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Voxware MetaVoice,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Voxware v1.1.6/1.1.8 File-Mode Codecs,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Voxware v1.1.8 Bitstream-Mode Codecs,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Audio Renderers:
ESS Maestro,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
DirectSound: ESS Maestro,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
Midi Renderers:
MPU401,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Communication Transforms:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,4.90.3010.0900
WDM Streaming Data Transforms:
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,4.90.3010.0900
Microsoft DirectMusic SW Synth (WDM),0x00200000,1,1,,4.90.3010.0900
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Tee/Splitter Devices:
WDM Streaming Mixer Devices:
Microsoft Kernel Audio Mixer,0x00200000,2,2,,4.90.3010.0900
BDA Receiver Component:
BDA MPE Filter,0x00600000,1,1,,4.90.3010.0900
BDA Slip De-Framer,0x00600000,1,1,,4.90.3010.0900
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,4.90.3010.0900
WDM Streaming VBI Codecs:
CC Decoder,0x00200000,2,1,,4.90.3010.0900
NABTS/FEC VBI Codec,0x00200000,2,1,,4.90.3010.0900
WST Codec,0x00200000,1,1,,4.90.3010.0900
WDM Streaming System Devices:
ESS Maestro,0x00000000,0,0,,
MPU401,0x00200000,2,2,,4.90.3010.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PSISRNDR.AX,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,MPEG2DATA.AX,6.05.0001.0900
    63.99 KiB
    directx first image
Reply 1 of 7, by zyga64
Mobile Pentium 3 Coppermine can change frequency on the fly. I have HP Omnibook 6000 (which is also Intel BX based) with mobile Pentium 3 1000 which can slow down to 700Mhz.
Don't remember if it is multiplier or FSB lowering. I think it is early implementation of SpeedStep technology which is not well supported after Windows 98.
Of course I can be wrong. It was quite a long time ago when I was fighting with this beast, and my memory may fail.
If I can suggest something - try to download driver pack for HP Omnibook 6000 from HP support site, and check if it does contain specific driver/update for this CPU feature.
(ok. I can answer myself - I doesn't...)
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 2 of 7, by kenrouholo
yes Pentium 3 already had Speedstep. I want to say the Dell P3 laptop I had did show varying CPU speed in software because of that but I guess I have to say that my memory isn't 100% clear on that, and I could be remembering incorrectly. But P3 mobile does have Speedstep for sure.
Yes, I always ramble this much.
Reply 3 of 7, by clueless1
Run an instance of Prime 95 while running CPU-Z to be sure Speedstep is not slowing it down.
Reply 4 of 7, by enloop
I looked over what Prime 95 does (a rough understanding about those perfect primes) but I don't see its role in affecting Speedstep? Does it isolate it or something?
This page I found that is a bit dated but seemed to explain it pretty well on Playtool.
But I still don't know how I should use this to help me here.
Reply 5 of 7, by clueless1
enloop wrote:
I looked over what Prime 95 does (a rough understanding about those perfect primes) but I don't see its role in affecting Speeds […]
I just meant to load the CPU while CPU-Z is running, it doesn't have to be prime95, it can be any cpu benchmark to forces the cpu to run at full speed while CPU-Z is detecting the processor.
Reply 6 of 7, by enloop
So... let's see if I got this. The CPU-Z is in charge of taking a "screenshot" if you will, of the system's current settings. This is achieved by running a benchmark which is to help determine the full speed of the cpu. But isn't there limitations placed on the CPU by the manufacturer? Or will the benchmark bypass that? And I feel like there's still other things to address like temperature and whatnot.
Reply 7 of 7, by clueless1
Just try it. cpu-z shows current operating frequency of cpu. it should also identify the cpu (regardless of current operating frequency). I just don't know if it's properly IDing your cpu, that's why I suggested loading to cpu up to see what frequency it maxes out at.
