First post, by tizzdizz
Hey guys,
I have a Data General P100 that I haven't run in a few months. I moved it to my office to tinker with it, and now it wont power on. Since the Dallas battery is luckily socketed, I'd like to replace it. If the battery died, would it prevent it from powering on, or just prevent it from progressing through the boot sequence?
I have to find another appropriate AT power supply (don't have any with 24 pins) so I can figure out what's going on.
Edit: I tried searching a few online sources, but I keep only finding the DS1287s, and no sign of any 1587s.
Reply 1 of 8, by i486_inside
Your best bet is to cut into the chip similar to the ds128(8)7 battery mod and solder a battery holder on to the chipt, this datasheet will help you find the Vbat and BGND pins.
    ds1585.pdf
    1.04 MiB
    75 downloads
Reply 2 of 8, by tizzdizz
Thanks, I had seen the battery mod for the 1287, I was just unsure if this was similar enough for it to work, and which pins need to be tied into. I'll see what I can find in the datasheet. Thanks for attaching it!
Reply 3 of 8, by i486_inside
I attached the datasheet on my post, the DS1585 and DS1587 are essentially the same, the ds1587 is a ds 1585 but on the ds1587 the vbat and bgnd as well as the oscillator pins are bent up and have the battery and oscillator soldered to them and then they pot the battery and oscillator in epoxy and put a plastic cover over it and stamp the dallas logo, the ds1587 part number and the date code on it.
Reply 5 of 8, by i486_inside
Actually now that I look at it, there is an auxiliary battery pin on the chip, so you may be able to use that instead of having to hack in to the chip, Actually, is there an external battery header anywhere on the motherboard that interfaces to the Vbaux pin?
Reply 6 of 8, by tizzdizz
Good question, I'll have to see when I get to the office tomorrow. But here's a picture of the board.
1.36 MiB
Data General P-100 motherboard
Reply 7 of 8, by dogchainx
I was searching for this part a month ago. Only place I could really find is this place, and its also called "Dantona COMP-99", though it only references a DS1587 as a compatible.
https://octopart.com/comp-99-dantona+industries-7154401
But I seriously doubt you want to buy a minimum of 10 of them at $45 each, or try to requisition-order just one (they might laugh at you...). I decided not to buy the motherboard that had the chip attached.
Let me know if you're able to cut into it like the other Dallas RTCs, as I've done that mod before with great success.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 8 of 8, by tizzdizz
Thanks dogchainx, I'll see what I can find out. I'm not even positive if this is bad, I'm just trying to diagnose a non-start issue where it won't power on.
