First post, by MKT_Gundam
i find this board, but dont have any model indetification, besides the bios and Toshiba sticker chip.
The cpu is a AMD 386 DX.
    1.33 MiB
    1.28 MiB
    1.45 MiB
    1.47 MiB
    The bios chip is: 386 dx BIOS 1989 AMI c-1216 ver. 2.11
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 1 of 12, by jesolo
Have a look at this site: http://arvutimuuseum.ee/th99/#1.
You might be able to identify your motherboard by comparing the layout to the other motherboards.
However, based on the pictures that you've uploaded, I would say that this is only a 386 motherboard - it might support the Cyrix/TI 486DLC CPU's but, there are no 486 sockets (the unpopulated socket is for your math co-processor).
Reply 2 of 12, by Anonymous Coward
PC Chips M321.
http://arvutimuuseum.ee/th99/m/I-L/33553.htm
Reply 4 of 12, by maksg
I need same help. Recently acquired Generic 386 Mainboard, 82C391 chipset, amd DX-40. Tried to find some documentation about this board and couldn't. Needs manual for jumper cache settings. Please help!
1.75 MiB
Reply 5 of 12, by mkarcher
maksg wrote on 2021-08-14, 04:53:
I looked for your board at Ultimate Hardware 19, the intended TH99 successor. I searched for that board using the filter "1 8-bit ISA slot", "6 16-bit ISA slots", "AMI BIOS". I didn't dare to include the Opti chipset into the filter, as I was afraid of missing your board in case it is categorized as "chipset unknown". Turns out, that fear was uncalled for, and if I had included the Chipset, there would have been only one result after filtering.
Your board is (a clone of?) the Shuttle HOT-307H: http://www.win3x.org/uh19/motherboard/show/4425
Reply 8 of 12, by maksg
dataino.it wrote on 2021-08-14, 17:21:
can u dump the BIOS in case is the version 1.x and better full pic for complete the DB
can you suggest any app for this? because ROM soldered right to mother... I have ROM reader TL866, but not sure this is good idea to desoldering it. maybe will try later...
408.8 KiB
Reply 9 of 12, by mkarcher
maksg wrote on 2021-08-14, 17:50:
Leave it soldered. On this forum, the usual recommendation to dump the ROM is NSSI.
Reply 10 of 12, by mkarcher
http://www.win3x.org/uh19/motherboard/result/?name=M321
thx
Be careful! There are two boards in this thread. The recent activity is about the Shuttle HOT-307H, your link points to the board originally discussed in the thread.
