First post, by diegotmc
Hello!
I recently bought some 486 hardware to start my retro PC project. But after several tries, cleaning, jumper settings check, voltage check with multimeter... I only get this:
462.85 KiB
Some random colored characters shows up immediately after power on, then this screen freezes for a two seconds, then all goes black and a low tone long beep is heard from the speaker.
The specs are:
SIS 471 rev. B motherboard
Intel 486 DX4-100
2x 16mb 72 pin EDO RAM
Trident 9440 VLB
Does anyone have an idea of what's wrong? BIOS corrupted? Video BIOS corrupted? Too much or incorrect type of RAM?
I've also uploaded this video showing all the startup process: https://youtu.be/twhQudznGaE
Reply 1 of 19, by cyclone3d
You wouldn't happen to have an ISA video card to test with would you?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 19, by weldum
at least the computer seems to be happy 😊
no, seriously, you have to make some testing with another video card, different ram, processor and such. by trial and error you can isolate the problem and fix it.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 19, by bakemono
I couldn't get EDO RAM to work with a SIS 471 board. Try moving the memory and video card to different slots, but I suspect you'll need different RAM.
again another retro game on itch: https://90soft90.itch.io/shmup-salad
Reply 4 of 19, by diegotmc
I'm suspecting that the problem is the memory modules... so I bought some 30 pin RAM and a POST diagnosis card. It should arrive this week. And let's see what happens now 😎
Previous owner of the mb + proc + video said that everything was working. I bought the EDO RAM from another person.
Reply 5 of 19, by Tiido
EDO definitely doesn't work on a SiS471, only FPM does.
Reply 7 of 19, by debs3759
oeuvre wrote:
The only true happiness comes in death.
That's very Zen of you 😀
Reply 8 of 19, by diegotmc
Ok, so the 30 pin RAM finally arrived. 8x 1mb sticks... and none of the 8 sticks are being recognized by the board 😢
MB is giving the long beeps (Award BIOS), and the test card gives the same code as if it wasn't any memory in the board.
Any ideas? Look for some FPM 72 pin RAM?
Reply 9 of 19, by debs3759
Your motherboard only supports FPM RAM. Are the 30-pin modules EDO as well?
http://www.elhvb.com/webhq/models/486vlb3/sis471b.htm
Reply 10 of 19, by diegotmc
I thought that all 30 pin sticks are FPM... 😐
Reply 11 of 19, by debs3759
I'm not sure. Were they sold as working, or was it pot luck?
Reply 13 of 19, by Tiido
My SIS 471 board has an army of jumpers for setting RAM banks/size and they have to be set right for things to work right.
Reply 14 of 19, by dondiego
Could be a non properly inserted video card, push the side farther from the connector first and check pin alignment.
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 15 of 19, by fitzpatr
To confirm, are you filling all 4 slots with 30-pin RAM?
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 16 of 19, by diegotmc
Do you know what jumpers is?
I only have the manual from here: http://www.elhvb.com/webhq/models/486vlb3/sis471b.htm
Yes, all 4 slots.
Reply 17 of 19, by Tiido
The info available seems not to tell what half the jumpers are...
Reply 18 of 19, by diegotmc
Maybe the info is here: http://stason.org/TULARC/pc/motherboards/V/VI … BUS-VLT-MB.html
JP36 and JP37.
I'll test it later!
Reply 19 of 19, by diegotmc
Ok, updates:
These settings that I posted are different from my board. But yesterday I started playing with some jumpers and found that JP41 probably is the one that selects the memory banks in use.
And then the system started to come to life!!
But it was very unstable. Sometimes no image at all, sometimes it showed up the Trident logo, beeps, and stops in a screen only with the cursor blinking, and 2 times it showed the next screen identifying the CPU as a 75mhz with the text grayed, and locks up...
Today the FPM 72pin memory arrived... and now it's working!
But the new problem is: I can't boot from the CF card. The system reboots everytime it tries to boot from the card.
I'm using a 512mb that is already prepared with MS-DOS 6.22 (i've tested it in my old laptop, and it's ok), and a cheap CF to IDE adapter like this one:
75.84 KiB
It was identified normaly in the IDE HDD auto detection.
Any ideas what's happening?
