First post, by mothergoose729
Just because I am curious, and it is fun to think about, imagine taking a modern i7 computer and putting in a retro friendly storage controller, an FX 5500 or similar PCI graphics, a windows sound card, and maybe a USB 1.1 controller. Could you get windows 98 installed on it, and more importantly, what would your framerate in Quake III be 🤣 ? What is the newest computer you could potentially get to run windows 98?
Reply 1 of 13, by cyclone3d
Well, people have already gotten newer i7 systems to run with Windows 98.
The fastest video card that has modded drivers that work with Win98SE is the Nvidia 7900GTX. The driver supposedly should also work with the 8800 Ultra/GTX but I wasn't able to get it to work. Pretty sure it is because those cards have over 512MB RAM.
Even newer onboard SATA controllers work fine in Win98SE. Sure it just uses the regular built-in 16-bit drivers, but it does work.
The fastest PCI SATA controller that has drivers for Win98SE is any card based on the Promise SATA 150 (SATA I only.. the SATA II 150 chip will not work).
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 13, by mothergoose729
cyclone3d wrote:
Well, people have already gotten newer i7 systems to run with Windows 98. […]
The 7900GTX AGP or PCIE? That would also mean that 320mb 8800GTS would be compatible? Crazy.
Reply 3 of 13, by agent_x007
I'm one of the madman that ran Win98 on Core i7 😁
I used PCI-e card (7800 GTX). 7900 GTX is best when you have one card, however it didn't worked for my specific use case.
ruthan is the other user that is into "Win98 everything and see what sticks" : LINK
PS. I didn't said 7900GTX wasn't tested 😉 so an answer for Quake III Arena question :
656.31 KiB
Reply 4 of 13, by mothergoose729
agent_x007 wrote:
I'm one of the madman that ran Win98 on Core i7 :D I used PCI-e card (7800 GTX). 7900 GTX is best when you have one card, howeve […]
Oh god I love it. 977fps? WE MUST GO HIGHER.
Reply 5 of 13, by Hamby
I may need to do this.
Once my 286 is built.
And my 486 is built.
And my K6-2 300mhz is turned into Win 98SE.
(and once my phone is built, but that's not retro so, nevermind).
The idea of running Win98 on modern hardware makes me drool.
For at least a decade I've wanted a version of DOS (FreeDOS, most likely) that would talk to modern video cards.
Guess I'll settle for Win98...
Reply 6 of 13, by cyclone3d
Yeah.. the G80 based 8800 GTS 320MB should theoretically work.
Now I haveta get me one and try it out.
YMF7x4 Guide
Reply 8 of 13, by cyclone3d
RaverX wrote:
With what driver? As far as I know, Nvidia doesn't offer Windows 98 for anything above Geforce 6.
Nividia didn't make an official release, but up to 93.71 can be made to work with 98.
https://msfn.org/board/topic/97786-geforce-67 … win98me-by-zak/
http://toogam.com/software/archive/drivers/vi … fici/nv8269.txt
YMF7x4 Guide
Reply 9 of 13, by mothergoose729
Please post back when you do! I am planning a windows XP build around a GTS 250 which is g92, but I could bump down to an 880gts if I also get win98 games. You can find them for about 20$ shipped these days on ebay. The 320mb VRAM models are guaranteed g80.
Reply 10 of 13, by cyclone3d
I snagged an unknown one - no clear picture of the sticker on the back for $9.00 shipped and a couple of 320MB ones for $28 shipped for both. All are EVGA and supposedly work.
I'll test once they arrive. Really hope they work. I completely forgot that the G80 series had 320MB GTS cards.
The 640MB ones are all going to be G80 as well, correct?
YMF7x4 Guide
Reply 12 of 13, by Kamerat
The JMicron JMB360 SATAII PCIe chip actually got Windows 98SE drivers, but it's not a very common chip on a stand alone controller and I'm not sure how it performs.
YouTube channel
Reply 13 of 13, by cyclone3d
Ooohhhh.. something else for me to keep an eye out for.
Edit.. well, I found some.. but they are only single port eSATA. The JMB360 only supports a single port and looks like it doesn't have a BIOS on the card so pretty sure it wouldn't be bootable.
However, the Adaptec RAID 1220SA has Linux driver source code available so it might be possible to make a 9x driver for it.
Still looking for other options.
Edit 2: Anybody have an actual verified link to Win98 drivers for the JMB360? All I can find is places saying that it supports Win98 but every single driver package I have been able to find doesn't have a Win98 driver. Really looks to be Win2000 or newer.
The exception is the RLoew custom driver... but I am looking for something that has support from the mfg.
Edit 3: Found a free Universal ATA driver and somebody did make a version that has support for Win 9x.
Main page: http://alter.org.ua/en/soft/win/uni_ata/
Page with Win9x version: http://reboot.pro/topic/2384-alter-group-univ … nt351nt42000xp/
The compiled Win9x version was compiled in debug mode and is a very old version and it doesn't look like the Win9x version was ever updated or included in the newer versions so I may have to take a look at that sometime to see if I can implement the Win9x compatibility in the newer versions.
YMF7x4 Guide
