First post, by pew
I am experimenting, trying to find the best way to use my old DOS programs.
Mac and Windows. vDOS, Boxer, DOSBox, VM Virtual Box and so on.
They all have advantages and flaws
With Boxer (wine on Mac) i have troubble finding the config-file. It does not exist. I need it for setting the diskdrives at startup.
I also have problems with copying new files to the disk. They simply dont exist before i have closed the instance and startet again.
With DOSBox on windows i have trouble with closing the DOSBox status window or preventing it popping up in the first place.
I also cant scale the window. There must be somewhere i can set the size.
I am no great programmer so i would ge greatefull for some help.
Best regards
Poul Erik
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Boxer is not Wine on mac, but a Dosbox fork. Why not use the original Dosbox on a mac?
The console window on Windows can be prevented by a commandline switch (that you can feed to the Dosbox shortcut), and scaling might be fixed by using a different output.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by eL_PuSHeR
[Thread Moved to DOSBox General Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 3, by BinaryDemon
For the DosBox Windows status window, have you tried the command line -noconsole to get rid of it completely?
