First post, by dreamblaster
Hi,
here's a prototype of the CHiLL MIDI module : this is based on CHiLL interface PCB, and a 3d printed 'dual color' enclosure.
Maybe I will also make a larger version that can house XR385 / DB50XG cards.
Send me a PM if you are interested in this. 😀
The attachment DSCN4623.JPG is no longer available
The attachment DSCN4621.JPG is no longer available
The attachment DSCN4618.JPG is no longer available
The attachment DSCN4617.JPG is no longer available
The attachment DSCN4612.JPG is no longer available
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 1 of 16, by keropi
very very nice!!!! the quality of the print is really excellent! almost like a mold?!
Reply 2 of 16, by 640K!enough
Agreed; nicely done! For my tastes, a more subdued colour scheme would be better. If you are still offering these by then, I may pick one up when my budget allows (it won't be soon).
Reply 3 of 16, by CHiLL72
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 4 of 16, by dreamblaster
New revision of the 'Medium size' CHiLL Enclosure.
It took over all improvements from CHiLL XL Enclosure.
My new prototype is in red/black color scheme
Any requests for other color schemes ?
Reply 5 of 16, by dreamblaster
The large CHILLBOX XL now has a little brother... Well let's call this one CHILLBOX M...
It replaces the old CHiLL Box at https://www.serdashop.com/CHiLLBox , there are various changes, the box is slightly larger and now features
the MIDI logo instead of the 'CHiLL' text.
The prints arrived. Red/Black color combo (as there were no suggestions for other color schemes...).
Reply 6 of 16, by Pickle
i have a x2gs and the phil/chil adapter and works fine as designed. I also have a coupe midi/gamepad cables where the midi in/out comes out on the 5 pin din connectors.
What im wondering is if I make a reverse adapter from 5 pin din to gameport and still use the phil/chil adapter. Or will this have problems that the chill enclosure would address?
I think i just need power and uart out and I think the DIN connector supplies that.
Reply 7 of 16, by dreamblaster
Pickle wrote on 2022-01-04, 14:30:
I'm not sure if i understand your question correctly
maybe this splitter could be of help ? https://www.serdashop.com/DB15-Doubler-Solder-Kit
Reply 8 of 16, by mkarcher
The DIN connector doesn't have power. If you want to connect the phil/chill adapter to a gameport, you can just use a 15-pin extension cable instead of the MIDI breakout cable, and call it a day. If you want to connect a joystick at the same time, use the db15 doubler linked by dreamblaster.
Reply 9 of 16, by Pickle
That would work and has the right idea, but im hoping i can use the cable for easy access. I have two midi cables so if it worked i could potentially switch the x2gs from either machine easily.
The cables i have already do the split so it has the 15 pin gamport connection and the two 5 pin bin connectors.
?u=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2FPX4AAOSwY4lgttwh%2Fs-l300.jpg&f=1&nofb=1
I want to connect the midi out (DIN connection) to a female gameport which would then be attached to the chill/phil adapter.
Im not certain but it seems pin 4 of the midi out DIN connector is pulled up to 5 V. (but might be current limited so not enough to power the connected wavetable?)
Reply 10 of 16, by MN_Moody
Pickle wrote on 2022-01-04, 18:09:
That would work and has the right idea, but im hoping i can use the cable for easy access. I have two midi cables so if it worke […]
I think this depends on your sound card providing 5v power to the designated pin on the MIDI connector, which I'm not seeing as an option via a standard joystick port based on published pinouts. I think you are going to have to purchase the gameport to MIDI adapter, connect it to your sound card and start checking pins with a multimeter to confirm this as I expect it's both dependent on how the DB15-MIDI cable is wired and the way the sound card implemented it's MIDI interface.
Reply 11 of 16, by Pickle
there must be 5v at the gameport since the phil/chill adapter and x2gs works, im going to beep test the pins on my cable. If that 5v line is on the midi out connector I think it could work.
Reply 12 of 16, by mkarcher
MN_Moody wrote on 2022-01-05, 03:12:
See https://en.wikipedia.org/wiki/Game_port : You get to have +5V (usually unfused!) on pins 1, 8 and 9 (traditional pre-midi game ports also have +5V on pin 15).
The typical gameport-to-MIDI cable schematics on the internet (see e.g. ebay cable, help! DB15 Gameport > MIDI with joystick pass through) have a resistor between +5V at the game port and pin 4 of MIDI out. This is the safest design, because it has one resistor between +5V and pin 4, and a second resistor between pin 5 and the inverter/amplifier. This makes both pins short-circuit proof. The cable would work as well (as long as no short circuits are present) with just one resistor on either line (which should be 470 ohms instead of 2*220 Ohm), so there is no necessity to have a resistor between +5V and pin 4.
If the 220 ohm resistor is there, that pin is useless for powering the Chill and Phil adapter.
Reply 13 of 16, by mkarcher
The cable already splits. That's the problem for your use case. The unfused unlimited 5V supply is only on the joystick connector, and the MIDI data is only on the MIDI out connector. The Chill/Phil needs both the raw 5V supply and the MIDI data. That's why I suggested to ditch your MIDI splitter cables, and just use a simple gameport extensionlike https://www.amazon.de/dp/B005UABIC4 to connect the Chill/Phil to your computers (or two of those cables, so you don't have to swap the cables at the computer). In case you want the +5V connected to the Chill/Phil and a joystick, you need a DB-15 splitter, so you get +5V to both sides.
Reply 14 of 16, by dreamblaster
CHiLL M , new color scheme : Computer Beige - Black
Reply 15 of 16, by digger
Question: I recently acquired a Yamaha DB50XG board, and I wish to use it as an external MIDI module. I need the XL edition of the CHiLL box for that, right? The M won't fit?
UPDATE: Ah, this other thread answers my question, and the answer is "yes". I should have searched better first, before asking this here. Thanks!
Reply 16 of 16, by dreamblaster
digger wrote on 2023-12-08, 10:55:
yes you'd need XL Chill Box for DB50XG
