First post, by Dragonslayer182
I'm trying to install the drivers for my SB Audigy 2 ZS, but I keep running into problems in windows 98. The default installer doesn't even detect the card, and the "hidden" installer in the d:\audio\drivers folder hangs near the end of installing the drivers. I've tried both audigy 2 zs install discs from the driver archive. The web installer doesn't detect the card either. I've made sure that it's fully seated in it's PCI slot, and that it's the only card in there. What is going on, and how can I get these drivers installed?
I've taken a pic of how far it's gotten and what it's managed to install before hanging: (Sorry about the huge size, I can't remember how to limit it)
Discord: Dragonslayer182#8984
Reply 1 of 12, by chinny22
Creative drivers are pretty bad round this time, its a pretty common problem.
You can try different PCI slots, or reinstall windows with the card removed and go again.
Although most the time device manager wont see anything what are the other missing drivers? maybe you do have a conflict?
Reply 2 of 12, by BushLin
Did you install the chipset drivers first?
There's a fair few unknown devices there.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 3 of 12, by Dragonslayer182
I just installed the chipset drivers and tried using the first PCI slot, but neither worked. I really hope I don't have to reinstall windows. Could there be a conflict between the onboard audio and the SB Audigy 2 ZS, and is there a way to resolve it? Onboard audio doesn't have drivers installed.
Reply 4 of 12, by kalm_traveler
Why not disable onboard audio in the bios?
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:iRyzen 9 9950X3D, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
Reply 5 of 12, by Dragonslayer182
Just tried that, still no dice... The only change is that the "PCI Multimedia Audio Device" unknown device isn't listed anymore.
Reply 6 of 12, by cyclone3d
1. What is the model number on the Audigy 2 ZS card
2. Do you have another computer you can try it in?
If it isn't even showing up an an unknown device in Windows before you install the drivers, there is no way that the card is going to work. The computer must detect it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 12, by Dragonslayer182
It's an SB0350, and I just tried it in an XP computer with similar results. Only difference is that this time, the hidden installer finished installing without crashing, though it shows up as a "Soundblaster Audigy [1000]", and no sound comes out when I test it. Both computers see that there's some kind of sound card in the PCI slot, but creative's software isn't picking it up.
Reply 8 of 12, by cyclone3d
Kinda sounds like a faulty card to me. I had that happen to a Live! and an Audigy 1 back in the day.
One other thought. Have you tried cleaning the edge connector with a pencil eraser yet? Could be that there is just some oxidation or dirt on the connector that is causing it to not work.
YMF7x4 Guide
Reply 9 of 12, by swaaye
Could it be an OEM card? I think the model numbers on the cards are the same. Creative's driver installers frequently wouldn't detect an OEM card. You need to get drivers from the system manufacturer.
With Windows XP and later you could try the Daniel K Audigy Support Pack. It will detect all Audigy cards.
Reply 10 of 12, by cyclone3d
And supposedly not have EAX support.
You should be able to see what the card ID shows up as in the device manager and then look in the .inf file for the drivers to make sure that it is in there.
YMF7x4 Guide
Reply 11 of 12, by Dragonslayer182
Okay, I just compared the device ID's. This card is 0004 (I think), and it's not listed in setup's INI file. I thought OEM cards had the normal colored connectors, but mine is completely gold and black. Is there any way to get this working in Win98se with EAX support?
Also, if you're wondering why it's got the correct name now: I'm testing this in my potential windows XP build to make sure it's not just windows 98, which has a couple of issues that need to be fixed before I turn it into a gaming pc (Nothing functional, just needs a new case and a quieter fan that doesn't blow as much air as a leafblower). I used a newer driver installer and it actually installed and detects my card as the right thing now... except that no sound comes out. At all. The digital out seems to make a little bit of sound when I plug it into that though, and I've also checked to make sure it's not muted or disabled or anything.
EDIT: I just realized that the "ID's" are language id's, not hardware ID's. I'm a moron. Does anyone know where to find the RIGHT .inf file in the disc's contents?
Reply 12 of 12, by PARUS
Remove driver via CTAPPZ.EXE and then try to force manually install VxD driver from Augigy1 disc. It should work. And at all WDM isn't good choice for Win9X.
