First post, by Braca862
Hello,
I recently downloaded the ISO of Chasm The Rift and installed it on my computer. Once I click on Chasm.exe, the demo plays, but for some reason, the keyboard does not respond. I press the Esc key to access the menu, but it doesn't work. Even with the patches, I still have this problem. Here are my specs:
Dell XPS t500
Windows 98 Second Edition
512MB RAM
1 Ghz Pentium III
Sound Blaster AWE64 Gold
Can anyone help me with this?
Reply 4 of 12, by dr_st
Let's check first if it's a problem with the entire keyboard or just with Escape.
Try jumping directly to the first level by starting the game as follows:
chasm -warp 1
And see if you can move around, shoot, etc.
Reply 5 of 12, by Braca862
dr_st wrote:
Let's check first if it's a problem with the entire keyboard or just with Escape. […]
chasm -warp 1
Okay, so here's what I discovered; after entering that command and starting at the first level, it turns out that while the keyboard still doesn't work, my mouse does! I can fire by left clicking, and I can move by pressing on the scroll button. That's just weird.
Reply 6 of 12, by dr_st
Do you happen to have a game controller plugged in? Maybe for some strange reason the game defaults to it and disables the keyboard?
Reply 7 of 12, by Braca862
Nope, no game controllers are plugged into the computer. Is there any config file within the game directory to try to change this?
Reply 8 of 12, by dr_st
Not as far as I can see. There is CHASM.CFG, but it is not human-readable.
Let's go back to the basics - is your keyboard PS/2 or USB? Chasm is a weird game; maybe they coded it specifically to work with a PS/2 keyboard only (if that's even possible). And try a different keyboard if you have such an option.
Reply 9 of 12, by Braca862
Yes, my keyboard is PS/2, and its the only one I currently have.
Reply 10 of 12, by dr_st
OK, another idea - maybe there is a timing issue that prevents Chasm from accessing the keyboard properly when the CPU is too fast? Can you try to boot into pure DOS and slow the CPU speed with a Slowdown utility (such as MoSlo or Slowdown by Bret Johnson - both can be found online) to something around Pentium/486 speeds?
Reply 11 of 12, by schmatzler
I don't think so. The keyboard works fine on my 1.4GHz Tualatin.
@Braca862: Did you install the last patch for the game? It is supposed to fix issues with fast CPU's:
https://web.archive.org/web/20090410053211/ht … chasm_files.htm
Reply 12 of 12, by Limpem
I know this is an old post, but I was having the same issue.
Although I didn't find what causes this issue, I did discover a workaround:
1. Install chasm
2. Patch chasm (download csmtcpip from https://web.archive.org/web/20090410053211/ht … chasm_files.htm )
3. Run fix.exe
4. Rename chasm.cfg to chasm.tmp (or any other name)
5. Run chasm.exe (will crash with an error)
6. Restore chasm.cfg
7. Run chasm.exe
I don't have a clue why this works, but I know it does.
I also created a simple .bat file to easily run chasm (since steps 4 to 7 need to be repeated after every reboot).
    start.rar
    121 Bytes
    59 downloads
430HX/P1 233MMX/64MB/S3VirgeDX,Voodoo1SLI(King Shaman)/AWE32
440BX/CelTualatin1400/512MB/Banshee, PowerVR PCX2/AWE64Gold
645DX/P4Northwood 3,5Ghz(Oc)/512MB/Voodoo5500/Vortex2
875P/P4EE 3,4Ghz/1GB/GeforceFX5950/Audigy2ZS
Z97/i3-4370/16GB/GeforceGTX960/X-Fi
