First post, by xjas
I have one of those really cheap IDE to USB cables, but it's a big pain to use. It doesn't have a dedicated power supply, so I have to fish out an ATX PSU & jump the power-on wires every time I want to use it, and I find it's completely hit-and-miss with drives under 20GB or so. Sometimes they need to be jumpered as master, sometimes as cable select, sometimes you need to hot-plug the IDE cable, sometimes you need to start with everything (including the PC) powered off, sometimes it just plain won't read a drive no matter what you do, etc.
I'm looking for one that's a little more reliable. I have a 2-bay SATA dock that's great; the type you insert drives in from the top like cartridges. I'd love one like that for IDE, but I need that compatibility with old drives.
Any suggestions?
Reply 1 of 4, by Scraphoarder
Bought on eBay a cheap "ALL IN 1 HDD DOCKING" and have used it sucessfully with a lot of IDE 2.5" and 3.5" drives on all types of brands except some WD HDDs that it didnt detect.
Reply 2 of 4, by Intel486dx33
I am hoping this one will work.
Should fit any size drive.
The large old IDE hard drives don’t fit in docks.
Reply 3 of 4, by maxtherabbit
the problem with most USB to IDE adapters is they only support LBA addressing, not CHS
so any drives that are super old like <2GB and don't support LBA will not work at all
Reply 4 of 4, by derSammler
It's even worse. Due to the way USB works, LBA is always used by these adapters, even for drives between 504 MB and 8 GB which may have been used with enhanced CHS addressing. If you connect such a hard disk via an USB adapter and LBA is used, you'll corrupt the data on it. This is true for CF cards via a card reader as well.
