Best way to shutdown a 386/486 ?
First post, by Intel486dx33
I would like to know what is the best way to shutdown a 386 or 486 computer.
I don’t want to ruin the hard drive, filesystem, software, OS , RAM, Cache , or Power supply.
So what do you think is the best way to shut it down ( turn off ) ?
I am running DOS 6.21 and Win3x.
Is there a DOS program or batch file to shut down the computer ?
Reply 2 of 23, by derSammler
When using smartdrive, always load it with the /X parameter. FAT is a very weak filesystem and can't really take interruption while writing, so you don't want write cache.
Apart from that, you don't shut down a DOS/Win3.x machine. Just turn it off when you're done. If you have virtual memory enabled in Win3.x, exit Windows first.
Reply 4 of 23, by Intel486dx33
Errius wrote:
I think you're supposed to press CTRL-ALT-DEL to flush the SMARTDRV cache before cutting the power. Is this what you mean?
Well, My IBM PS/1 has a proprietary power switch and power supply.
In Win3x the power switch does not work.
So I can exit to IBM DOS menu and then select to go to DOS command line.
But in the command line the power button still does not work.
So what I am doing is at DOS command line I perform a “Control-alt-Delete”
To reboot the computer and at this point the power button works again so I can power off the computer.
I don’t think there is anything wrong with the power switch or power supply.
I just think this is the way this IBM PS/1 Is engineered.
Maybe there is a bios setting I need to look at ?
Reply 5 of 23, by Anonymous Coward
I like to yank the plug from the wall while Windows is busy doing something important with the file system. Screw soft power off, this is how real men shut down their computers.
Reply 6 of 23, by Intel486dx33
So to setup smartdrive.exe you just enter it into autoexec.bat with /X parameter ?
Reply 7 of 23, by Errius
Yes that's right. Put it in your AUTOEXEC.BAT.
It make sense since nobody is using their retro computers to write large amounts of data to disk.
Is this too much voodoo?
Reply 8 of 23, by Caluser2000
Never had a 386 or 486 that didn't switch off when the systems power button is pressed and that includes PS/1s in the 30 years I've used them.
Reply 9 of 23, by Caluser2000
No you don't have to do that. At the Dos prompt just wait about 5 seconds after drive activity is stopped and turn it off using the systems power button. Nothing magical about it at all. On more sophisticated OSs such as OS/2/*nix, hell even Win9x, it told you when to turn off your system or your system is halted ready for power off.
Reply 10 of 23, by FAMICOMASTER
I exit to DOS, do a CLS, and flip the switch.
If the machine has an MFM/RLL/ESDI hard drive, I run PARK.COM first.
That's it.
Reply 11 of 23, by realnc
I never disabled the write cache. It hurts performance. I used a simple batch file called "FLUSH.BAT" and put it in C:\DOS that contained:
SMARTDRV /C
This flushed the cache to disk. I simply typed FLUSH before switching the computer off.
Reply 13 of 23, by jmarsh
Errius wrote:
I believe PARKing the drive is only needed if the computer is going to be physically moved.
No.
Early drives should always be parked to avoid the heads landing on the usable areas of the platters.
Later drives (pretty much IDE onwards) auto-park when powered off.
Reply 14 of 23, by maxtherabbit
SMARTDRV /C
This is correct
Reply 15 of 23, by Caluser2000
maxtherabbit wrote:
SMARTDRV /C
This is correct
That is ONE way not the ONLY way of shutting down a 386/486. The user may be using another hdd cache, no cache or any number of other configurations such as networking, TSRs etc needed to be shut down to power down.
Reply 16 of 23, by Intel486dx33
Yeah, My 486 IBM PS/1 has a feature called "Rapid resume" it is like "Hibernation mode" for the Win-3.1 on 486 computer. If you have this feature turned on then I assume you are never suppose to
turn off the computer. You are suppose to let this feature manage the computer and it will go into Hibernation on it's own after 15 minutes.
If you turn this feature off then the computer works like a normal 486 and you can turn the computer off with just the Power button.
Reply 17 of 23, by Caluser2000
So you obviously disable the feature. After all you only play games on it as stated by your previous posts. So no precious data will be destroyed. Have you considered this quick resume feature may be the cause of your systems boot loop?
Reply 18 of 23, by maxtherabbit
Yes, I was only agreeing with that being the correct way to flush the SMARTDRV cache. Obviously that wouldn't apply if the user is not using SMARTDRV
Reply 19 of 23, by Caluser2000
Thought it was time to recap.
1.22 MiB
486
976.79 KiB
386
