First post, by p6889k
Just purchased BCM BC845DL industrial board for P4. This one has AGP 4x, 5x PCI and 2x ISA slots. While I'm waiting for it, I was curious if any of you have an experience with it (or its chipsets) and have anything useful to share. My goal was to try to find a P4 board that has AGP for modern GPU and ISA for sound card. This one has both.
Here's a link to specs sheet: http://www.bcmcom.com/tech/BC845DL/BC845DL-2.htm
And here's a link to manual:http://www.bcmcom.com/bcm_search_results.asp? … vel2=&asd=%5E54
It comes with Win9x/ME/2K/XP drivers.
The specs sheet says: "Pentium 4 up to 2.6 GHz or above (with system bus frequency of 400 MHz)"
Not sure what the max cpu for this is - any ideas? The manual doesn't specify it either. I'm guessing any P4 with 400MHz FSB?
Right now I have at home an unused Northwood P4 2.8GHz which needs 533FSB. Can I mess anything up if I put 533 FSB CPU into board that only supports 400FSB or will the cpu simply be underclocked?
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
Reply 1 of 10, by Horun
Yes it appears it runs only at 400 Mhz so your 533mhz cpu will run underclocked IF it is recognized by the BIOS at all. Well from what I read there are a few things that I would not like. How much did you pay for this board ? Not my business but there are better 478 boards but they are probably more expensive. The manual has errors which bother me if it were mine:
1. image 3.1 shows back panel. Is not same as 3.6.6. (one has two com, other is one com and a vga)
2. It does not state which 845 chipset is used (845G/845GL/845GE/845GV) the GL is the only one with 400Mhz only bus, the other do 400 and 533.
3. manual states 2x/4x AGP but requires 1.5v AGP card. Most 2x AGP were 3.3 so it is not a very AGP compatible board.
Reply 2 of 10, by p6889k
pricewise was a lot cheaper than other p4 industrial boards.
What other boards would you recommend?
I think 1.5v 4xAGP will be ok. I have several 8x 1.5v AGP cards which should work at 4x AGP, they may just run little bit slower.
I'm hoping this combo will give me a reasonably priced and fast win98/XP PC with ISA sound for dos games that are not cpu speed sensitive - i'll build something from pre Pentium era for that.
Btw, I also picked up 2.8GHz P4 with 400FSB for $6 just in case my 2.8/512/533 doesn't work at 400FSB.
etc.
Reply 3 of 10, by PC Hoarder Patrol
Last couple of bios updates
10092105.zip
196.97 KiB
10 downloads
10092106.zip
200.59 KiB
11 downloads
Reply 4 of 10, by dionb
I'd say it does say the chipset - the original 845 (without additional letters), hence only supporting PC2100 DDR.
I wouldn't worry about AGP 8x cards running at 4x - the AGP bus speed was rarely a real-world bottleneck, certainly not with the slow RAM and FSB of this old board, and as for no 3.3V AGP - that's just par for the course with P4 chipsets. Some truly universal AGP board were made, but they weren't common.
Reply 5 of 10, by p6889k
10092105.zip
10092106.zip
I'm curious, where did you find the 1.06 BIOS, the manufacturer only lists 1.05 on their web? Do you have any firsthand experience with this board?
etc.
Reply 6 of 10, by PCBONEZ
With that specific board no, but with BCM yes. I've had several of them since 486.
As industrial boards they usually aren't upgradable much beyond the original specs.
(That is typical for industrial boards, so to be expected.)
Those I've had were well built and solid/reliable.
Some were more difficult to initially configure than average but once you work it out you don't have to worry about them.
I quite like the brand.
Reply 7 of 10, by PC Hoarder Patrol
It's listed as the latest bios on the BCM Wayback archive for the board between Oct 2004 & Oct 2006, but by Nov 2007 only v1.05 is listed (maybe a board revision made v1.06 obsolete?)
https://web.archive.org/web/2008*/http://www. … vel2=&asd=%5E54
All the bios archive links seem dead, but I found the v1.06 one here, https://www.driverguide.com/driver/detail.php … driverid=237377
Also, no experience with this board - sorry!
Reply 8 of 10, by p6889k
So I played around this weekend with the BC845DL and didn't have much success with DOS sound. The board looked brand new, Win98 installed easily, all devices and drivers loaded properly. I plugged in AWE64Value, sound under Windows worked, but not under DOS. I setup Autoexec.bat with CTCM and AweUtil, CTCM reports that only 2 of 3 creative devices were successfully configured. Running Creative Diagnose detected the card and played sounds successfully, but DOS games don't detect the card. I spent way too much time messing around with BIOS settings and eventually gave up. I swapped ISA slots, disabled all devices in BIOS that are not needed, reserved IRQs, DMAs, etc. I'll have to try again one day.
One weird thing is that according the the board's specs sheet and manual, it's supposed to have WhizPro Bios, but my board has a Phoenix bios chip with Award bios loaded, which means i couldn't upgrade BIOS to a newer version as BCM only lists WhizPro bios not Award. I didn't find any references on the internet where this board would be supplied with Phoenix/Award bios. Also, there is no marking on the board that actually says it's BCM BC845DL board, visually it looks exactly the same, specs match, the only exception is the bios discrepancy. Is this normal with BCM manufacturer to not clearly label their boards or to switch BIOS chips?
As an alternative I also have MB820 P4 industrial board with 875P chipset. AWE64 in DOS worked right out of box in it with no need for any Autoexec.bat configuration. The MB820 board has newer features (USB2, AGP8, 4xDDR slots, 533/800FSB), but I would still like to get the BC845DL working eventually.
etc.
Reply 9 of 10, by balrog
I can confirm that Whizpro BIOS v1.06 enables LBA48 support (just flashed it on a board).
It's very strange that they removed it from the website, I wonder why.
I wonder what the case is with p6889k's Award BIOS board. Is there a date stamp on the BIOS? Does it support LBA48?
Reason: typo
Reply 10 of 10, by p6889k
balrog wrote on 2020-03-05, 17:27:
Unfortunately I no longer have the board. I ended up moving to Ibase MB820 P4 board with ISA, that is working great.
etc.
