First post, by appiah4
I have this card, and I am using a homemade breakout cable to get S-Video out from it. Except, I can't seem to get any video whatsoever in MS-DOS. The cable was made according to these pinouts and I triple checked it to make sure it is correct: https://pinouts.ru/Audio-Video-Hardware/ati_v … ut_pinout.shtml
At this point I can only speculate that this card's TV Out functionality needs to be enabled by a Windows driver or something and does not work in MS-DOS; but I can't find a way to verify this in any way. If anyone has this card and can check their TV-Out works in MS-DOS or not, I would be very grateful.
Reply 1 of 10, by RaverX
I have the card, the layout its a bit different, it has a slot for extra ram, but it's almost identical. It was my main card back in the days (1998) in a Cyrix 233 computer. The problem is that I don't have any device with S-Video input to test it. I think I still have somewhere an external TV Tuner that might have S-Video input, but I'm not sure. If I find it I'll try to test. I assume you want to know if the card can boot from start with S-Video output (BIOS, DOS).
Reply 2 of 10, by appiah4
RaverX wrote on 2020-02-12, 15:34:
That is exactly what I want to know, and I would be incredibly grateful if you can test that out!
Reply 5 of 10, by Jorpho
appiah4 wrote on 2020-02-12, 20:24:
That page is the video out pinout..
This page? The one titled "ATI All-In-Wonder input from S-Video / composite Video / Audio cable pinout" ?
Reply 6 of 10, by Doornkaat
I found a pinout here (second picture) that I haven't verified yet, could be for another AIW card as well. Give it a shot maybe?
Btw: if that's an original picture your card may have a remainder of the original cable still stuck in the Video Out port.
Reply 7 of 10, by Jorpho
...Actually, now that I think about it again, there was an occasion when I was trying to get my AIW Pro to do TV-out, and it refused to do it at boot until I finally gave up, plugged in a monitor, and enabled TV-out in Windows. Then it would do TV-out at boot. I can't recall any details like if it would stop working if I did a hard reset.
Reply 8 of 10, by appiah4
Jorpho wrote on 2020-02-12, 21:51:
Page title is wrong if you check the card manual still hosted on AMD site miraculously that cable is an AV Out cable. The AV in cable has red/white female tos plugs.
Reply 9 of 10, by appiah4
Jorpho wrote on 2020-02-13, 03:13:
That is how I think it is. Some confirmation would be awesome.
Reply 10 of 10, by appiah4
Doornkaat wrote on 2020-02-12, 23:31:
That is the cable for Radeon AIW cards.
I removed the part in that socket after I took the photo and realized it was there 😁
