First post, by borgie83
Hi guys. Could someone please upload the P16 Bios for me for the Intel SE440BX-2 motherboard? I'ts been removed from Intel's website like the rest of their retired products and I thought I had it backed up but I cant seem to find it.
Thanks 😀
EDIT: Even the P17 Bios should be ok. I've only ever used the P16 Bios though.
Reply 2 of 17, by Horun
darry wrote on 2020-03-02, 03:01:
Yes a good site for old Intel
ftp://ftp.spez.com.ua/driver/mb/intel/se440bx2/ for all files
also Rebyte.me has some
https://rebyte.me/en/intel/134527/?fileTypeId=4
Reply 3 of 17, by borgie83
Legend! Thanks for that mate. Much appreciated.
Reply 4 of 17, by borgie83
On another note, from memory, I remember using the P16 bios as I managed to get the 1ghz P3 working fine with this bios even though it wasn't on the cpu support list. Has anyone used the P17 bios with a 1ghz P3 using a SE440BX-2? Wondering if the P17 was specifically for the OEM version of the SE440BX motherboard which was called a SE440BX-3.
Reply 5 of 17, by PC Hoarder Patrol
P17 was a valid update for the SE440BX-2
ftp://ftp.spez.com.ua/driver/mb/intel/se440bx2/72585615.pdf
including the later PBAs with the widest cpu support
ftp://ftp.spez.com.ua/driver/mb/intel/se440bx … /cpusupport.htm
Reply 7 of 17, by gdjacobs
bearking wrote on 2020-03-03, 06:08:
I have P17 on my SE440BX-2, later revision of the board, and I could'n pass 800 MHz!
What FSB clock?
Reply 8 of 17, by PC Hoarder Patrol
Think the issue on the SE440BX-2 is that the combination of the correct PBA version & P17 maintains coppermine support but traps (with a system halt) any unsupported processors (similar to what it does with my SR440BX). My Dell OEM SE440BX-3 (with the latest P11 bios) has no problems with 1GHz support.
Reply 9 of 17, by bearking
gdjacobs wrote on 2020-03-03, 19:03:
What FSB clock?
100 MHZ FSB; board version/revision is AA 754558-304
Reply 10 of 17, by bearking
I've just downgraded the bios to version P16 and it's working with a P3 1 GHz FSB 100 skt370 on a socket adapter with voltage selection on auto...
432.62 KiB
240.35 KiB
369.33 KiB
395.67 KiB
Reply 11 of 17, by borgie83
bearking wrote on 2020-03-03, 21:09:
Very interesting. So I'm better off avoiding the P17 bios all together and sticking with P16 as my SE440BX-2 mb is using a P3 1ghz SL4KL 100FSB CPU. Strange how Intel decided to break compatibility with this cpu as I've had it running stable for years using P16. Just needed the bios above as I'm just about to start another build.
Reply 12 of 17, by SPiKA85
Hello!
The "se2bio16.exe" file contains the P16 BIOS and also the ROM Flash App?
So I just execute that file and it will flash the P16 BIOS?
Since I don't have a working floppy... can I burn a bootable DOS/Win98 CD and flash the BIOS from the CD-ROM?
Thanks!
Reply 13 of 17, by PC Hoarder Patrol
Actually you're skipping a step - the file se2bio16.exe does contain all the necessary files but they're in compressed format designed to create a bootable floppy. If you don't have a working floppy drive you'd be quicker to download the following file
http://cwcyrix.duckdns.org/intel-legacy-files … BIOS/SE2P16.zip
which has all the necessary files - including AUTOEXEC, BIO file & flash app - already fully expanded so you can prepare your own choice of bootable media.
Reply 14 of 17, by SPiKA85
PC Hoarder Patrol wrote on 2020-06-28, 23:18:
Hi!
Just to make sure... in MS-DOS, I have to execute "IFLASH.EXE" and load the "P16-0023.BIO" file, right?
Sorry... just got confused with the multiple files...
Thank you very much!
I don't want to mess something up... these boards are hard to get nowdays...
And it's been like 20 years that I don't use DOS so I kind of forgot many of the DOS commands xD
Reply 15 of 17, by Horun
Yes. In the autoexec.bat file the following command is given:
iflash /p P16-0023.bio
I would exactly that command.
Reply 16 of 17, by PC Hoarder Patrol
This^
or I'd just run AUTOEXEC.BAT, so if you're creating bootable DOS media (hdd, cd/dvd or usb) it will run AUTOEXEC.BAT by default and which contains the command iflash /p P16-0023.bio or if not from bootable media you can just run AUTOEXEC.BAT at the DOS prompt for the same effect.
Reply 17 of 17, by NyLan
For reference, I put all I found regarding this mobo, Bioses, Docs, in this "Mirror" of the old Intel's Website. For CPU Support, the board revision ( AA number ) is really important and was - partially - explained in the below website.
http://nylan.info/SE440BX2/
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
