First post, by Eon
Hey guys,
So i bought a ibm 770z in relatively descent shape.
There was no hdd with it.
The attachment 20200312_161845.jpg is no longer available
My question is : do you need one to access the easy-boot menu?
because i can't access it at all i changed the cmos and bought a new charger for the machine.
I still need to find the hdd caddy that goes with this computer.
In the meantime,i would have loved to do some setup in the bios and easy boot.
Cheers!
Reply 1 of 19, by aha2940
I don't think you need a hard drive to access the BIOS setup of any machine. Are you sure you have the right key combination to access it?
Reply 2 of 19, by ragefury32
Did you hit F1 when you see the Thinkpad logo to access the menu? If not, hold down F1 and see if it'll get you into the diagnostics.
Reply 3 of 19, by _Rob
You should be able to access the BIOS regardless if a HDD is installed by keeping F1 pressed on boot. I had the TP770Z myself back in the day. Do you get any post errors?
Reply 4 of 19, by Eon
Hello thanks for the reponse
So yeah i do hit f1 but it get stuck on the boot up screen like this
The attachment 20200323_141516.jpg is no longer available
Can the bios be corrupted on this model?
The keyboard works fine i had a few bios error because the battery was bad i changed it.
Cheers!
Reply 5 of 19, by _Rob
So you get a memory count, but then nothing? No beeps or error codes or anything? Is the speaker connected?
Can you try to take out some memory, or re-seat the memory?
Reply 6 of 19, by aha2940
Eon wrote on 2020-03-23, 13:19:
Hello thanks for the reponse […]
Cheers!
Not sure if yours is the same, but on my thinkpads, pressing F1 is not enough, I have to keep it pressed all the time until it enters the BIOS.
Reply 7 of 19, by Eon
Hello again,
it was the ram i removed it and hit f1,
The attachment 20200323_181129.jpg is no longer available
it works!
Thanks for the help
Now to find this:
The attachment 201718a.jpg is no longer available
The original Hard drive caddy or just the connector so i can make an adaptor
Anyways Cheers!
Reply 8 of 19, by Unknown_K
From what I remember the 770 series is the only one that used that type of caddy and luckily for me all my units came with one.
Unlike most Thinkpads the 770 comes with a special caddy box and a special cable inside the box that connects to the HD.
The attachment ibm 770 thinkpad hd cable.jpg is no longer available
Reply 9 of 19, by _Rob
If I remember correctly it can boot from CD or DVD. Not sure if it could boot from USB, I don't think so.
Unfortunately it pre-dates integrated Ethernet, so no boot from LAN.
Reply 10 of 19, by Eon
Hello again,
If you guys know someone that can sell me one, send them my way.
For now, i'm going to try to boot it up from cd to see if i can do it.
Thanks again, cheers!
Reply 11 of 19, by _Rob
Just get yourself a 32-bit Linux Live CD image. It should just work. I remember installing Linux on it back in the day and it worked. You might just have some problems with video as there is no modern kernel mode driver for the video chip, so you need to either use the old X11 driver (which some distros don't include any more), or fall back to VESA.
Reply 13 of 19, by ragefury32
You can try -> https://www.impactcomputers.com/12j0426.html, but you'll need to make sure that the drive comes with the caddy, or else it's moot.
AFAIK the hardaware maintenance manual does not list a model # just for the caddy itself.
Reply 14 of 19, by Eon
ragefury32 wrote on 2020-03-24, 14:51:
Thanks for the site i think i found the adaptor
it's not cheap thou!
https://www.impactcomputers.com/11j8942.html
Reply 15 of 19, by ragefury32
Eon wrote on 2020-03-24, 18:37:
Thanks for the site i think i found the adaptor […]
That's not the primary HDD caddy - that's an adapter that allows you to put a second HDD in the removable ultrabay.
Take a look at https://cdn-yams.schibsted.com/api/v1/imagest … .jpg?rule=mview
AFAIK the primary HDD caddy is not sold by itself by IBM (or vendors) unless it's from a liquidator, the primary caddy is supplied with a drive.
Reply 16 of 19, by _Rob
You should be able to boot from the Ultrabay adapter. Boot options can be set in the BIOS. It connects as a master to the secondary IDE controller.
Reply 17 of 19, by Eon
Hello again,
Thank you for all your help i found a caddy and an hhd that go with it.
Now i'm in driver nightmare, i installed win98.
Would love to find an iso or a real disc for a driver recovery.
Thanks again
Reply 18 of 19, by Bondi
Some recovery discs for TP 770 are available here https://archive.org/details/LegacyThinkPadRecovery
One of them was German AFAIR
There is also a guy on thinkpads forum that can help
https://forum.thinkpads.com/viewtopic.php?f=11&t=128170
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 19 of 19, by Eon
Hello again,
I completely forgot to post. I found a fix for the recovery disc problem.
On this page https://forum.thinkpads.com/viewtopic.php?f=6&t=132294.
Oh and btw for anyone looking for recovery disk the guy from forum.thinkpads won't give you any if you are not an active user for some time already on the forum and have actives posts.
Thank you all for the help.
