First post, by captain_koloth
What is the "most OS-y" thing you can do for each OS? The signature thing you do for each OS after setting a new retro build or VM to "verify" to yourself that it's satisfying that nostalgic urge?
For example, for me it's:
XP: Set Bliss background and play Space Cadet pinball
3.1: Play Ski Free
What are yours?
Reply 3 of 39, by Zup
- Windows 95: Get your first BSOD.
- Windows Plus!: Try every theme, cursor and sound combination... and decide to use the default settings.
- Windows XP: Get rid of the themes service.
I'm selling some stuff!
Reply 4 of 39, by schmatzler
Windows 98:
Disable Task Scheduler with msconfig and enable file extensions and hidden files in the folder options.
Windows XP:
Patch uxtheme.dll and install a dark theme. After that, enable file extensions and hidden files in the folder options.
Windows 10:
Install the Linux subsystem and Debian. Then run Winaero Tweaker to disable advertisements and telemetry and get a bash on right click.
MacOS:
Run a bunch of console commands to make sure it doesn't create DS_Store files. Run a console command to prevent it from adding attachments as thumbnails in the mail program. Install MountainDuck to get around the fact that the Finder is garbage software. Install Chrome because Safari is terrible for web development. Eventually realize that the OS itself is a raging dumpster fire and go back to Windows 10 😄
Bonus - Android:
Root the system with Magisk and install AdAway to remove ads in every browser and application.
Reply 6 of 39, by boxpressed
For both 98SE and XP, the first software I install is Norton Ghost 2003. Once I image the fresh install, I feel a lot more comfortable mucking around by adding drivers, etc. A fresh install of XP SP2 still fits on a CD-R.
Reply 8 of 39, by Errius
In the bad old days, before routers were common, the first thing to do after installing Windows 2000 was to install a software firewall. (Who remembers ZoneAlarm?) If you forgot to do this your computer would soon be loaded with viruses, without even launching a web browser.
“I like to dissect PCs. Don't you know I'm utterly insane?"
Reply 10 of 39, by Caluser2000
Install Linux and play xbill...that is all........
Reply 11 of 39, by Standard Def Steve
DOS 6.22: Give the floppy drive a good workout and install some games!
Win98SE: Give the CD drive a good workout and install some games!
WinXP: Give the DVD drive a good workout and install some games!
Win10: Give the modem and router a good workout and install some games!
Linux: Give Firefox a good workout and read about some games!
Mac OS: Throw up all over it, making the computer look not unlike a flower power iMac from 2001. You know, the kind that came preloaded with Bugdom. That really was some game!
Ten Gigahertz
5 Groovy GHz: Ryzen 9 5900X | GTX 1080 Ti | 64GB DDR4-3600 | 2TB NVMe, 8TB HDD | Win 10
5 Troll GHz: AMD FX-8350 | Radeon R9 Fury | 16GB DDR3-1866 | 500GB SSD, 2TB HDD | Win 8.1
Reply 12 of 39, by Kreshna Aryaguna Nurzaman
  1. Create an empty partition to contain pagefile.sys.
  2. Move pagefile.sys to the said partition.
  3. Turn off autorun for all drives.
  4. Explorer -> Tools -> Folder Option -> View, then show hidden files, extensions, and Windows-protected files.
  5. Set group policy to prevent any users other than administrator from installing applications.
  6. Replace Windows' HOSTS file with my customized HOSTS file to block ads and other undesirables (like corel.com).
And yes, those are parts of my obsessive-compulsive disorder.
Kreshna Aryaguna Nurzaman.
Reply 13 of 39, by dr_st
I do (3) and (4) on your list. Moving the pagefile to a different partition doesn't really serve a purpose; you have to use a different physical drive for it to have the desired effect. Also, you need to have some pagefile on C: (maybe a small one) to save crash dumps (if you care).
Reply 14 of 39, by konc
old OS for retro use: get an image with nothing but the drivers installed, for when I screw it up installing dozens of things
modern OS: not much these days, I guess installing my preferred audio/video players and browser extensions is a must for me
Reply 16 of 39, by chinny22
leileilol wrote on 2020-04-30, 11:06:
95C: Ctrl-Alt-Del to stop the 'installer'
Taking the CD out during that last boot or leaving out the non Win95-XX CAB files out of your install folder "automates" this for you.
but definitely a necessity
Reply 17 of 39, by computerguy08
I always install StartisBack++ after Windows 10 finished installing. I just can't stand the new Start menu with all of those tiles. My personal taste.
Looking for a motherboard? You can find it in Ultimate Hardware 2019: http://www.win3x.org/uh19/motherboard/search
Join our UH19 Discord server here: https://discord.gg/HWWH7hsk2p
Reply 19 of 39, by cyclone3d
austinham wrote on 2020-04-30, 16:15:
Dose no one here install the drivers for the system? 🤣 haha.
Anyway I start by installing the software for the system.
That's what I was going to ask.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
