First post, by lackofpatience
Hey guys,
I'm wondering if someone can help me out with some DOS sound support.
I've got a SoundBlaster Audigy 1 SB0090 PCI soundcard.
It seems DOS support has been done before with this card as well as the Audigy 2.
I've found the following but i've had issues. Mostly I suspect is my lack of understanding.
The drivers from here,
audigy dos drivers
They were missing a config ini file when loading.
And the drivers from here:
http://vogonsdrivers.com/getfile.php?fileid=4 … menustate=43,36
These could not find the PCI soundcard.
Looking at the attached images and my auto exec file, what am I missing?
SET PATH=%PATH%;C:\PROGRA~1\ATITEC~1\ATICON~1
SET BLASTER=A220 I5 D1 H5 P330 T6
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
C:\DOSDRV\SBINIT.COM
I guess the drivers I have tried can't get to the PCI card on that IRQ or Address?
Cheers
Mitch
    200.22 KiB
Reply 1 of 12, by AvalonH
Add the following line "Set CTSYN=c:\DOSDRV" without the quotation marks in your Autoexec.bat file BEFORE the line
That is assuming that your Audigy Dos drivers are located in the directory c:\DOSDRV .
Sbeinit.com wil then be able to find the CTSYN.INI file that holds the config setting for the SB16 emulation - IRQ, DMA, Wavetable *.ecw file etc.
I don't know if you need to run SBLOAD.EXE , i'm not sure what it does but I don't run it and the Audigy Emulation works without it for me.
Reply 2 of 12, by lackofpatience
AvalonH wrote on 2020-04-30, 14:53:
Add the following line "Set CTSYN=c:\DOSDRV" without the quotation marks in your Autoexec.bat file BEFORE the line C:\DOSDRV\S […]
Thank you for that, I will give that a try this morning! 😀
Reply 3 of 12, by lackofpatience
Sadly I get the same error. Should I try this line with one of the other driver packages?
    1.16 MiB
Reply 4 of 12, by darry
lackofpatience wrote on 2020-04-30, 21:34:
EDIT : I meant these drivers won't work : http://vogonsdrivers.com/getfile.php?fileid=4 … menustate=43,36
You have the wrong drivers .
Excerpt from the readme.txt :
The SBPCI.zip archive contains the dos sound card drivers for all Sound Blaster pci cards (excluding SBLive! and Audigy Models).
Reply 5 of 12, by lackofpatience
darry wrote on 2020-04-30, 21:53:
What I get for doing this too late last night! haha oh man,
I will go and search for some more appropriate ones. Or do you happen to have a source for some?
Cheers
Reply 6 of 12, by darry
I extracted the DOS drivers from the Audigy 1 package you linked to for you and zipped them up .
Reading Sbeset.txt should help you get started .
    sb16dos.zip
    277.88 KiB
    414 downloads
Reply 7 of 12, by lackofpatience
darry wrote on 2020-04-30, 22:50:
Many thanks Darry, I will give those a try!
Reply 8 of 12, by lackofpatience
I thought I should follow up on this as there was some missing parts that I managed to piece together. I was still having issues from files missing to no config files etc.
The drivers above and the ones from the Audigy CD rom seemed to be missing two components.
Struggling to get SB16 Emulation working with Audigy 2ZS in Win98
http://wysiwyg.bg/music%5Fsoftware/drivers/so … /sblive/DOSDRV/
http://files.creative.com/manualdn/Manuals/TS … 787/english.pdf
These pages led me to the these two files that needed to be packaged with these drivers/apps.
CTSYN.INI (goes to the C:\Windows directory)
DEFAULT.ECW (goes into the DOSDRV folder, also open the CTSYN .ini to edit folder path of the SBdrivers DOSDRV etc)
Thanks again for your help, I will package these up at somepoint and leave them here if anyone needs to do the same.
Cheers
Mitch
    1.7 MiB
    1.08 MiB
Reply 9 of 12, by realbadpainting
lackofpatience wrote on 2020-05-11, 09:17:
I thought I should follow up on this as there was some missing parts that I managed to piece together. I was still having issue […]
Cheers
Mitch
Hey Mitch, I was wondering if you would mind packaging these up and maybe writing up a total noob tutorial on how I can make this work? I'm having the same issue - I've got a Sound Blaster Audigy Gold (SB0090) installed on my 98 machine. Works great with Windows games but I can't get anything DOS-based to run. I'm trying to play old Build engine games from GOG releases with no luck!
Reply 10 of 12, by _StIwY_
So the Audigy 1 is basically like the Live! on both compatibility and audio quality overall ? I just got an SB0090 ( Audigy 1 indeed ). I read also that is the latest Creative card which had the SB16 Emulation DOS drivers included.
Reply 11 of 12, by RedSarg99
I noticed the dos drivers never loaded due to a pci card being detected. When I switched the bios to manage all resources it seem to resource the ISA to pci resource conflict which the driver might be detecting. This is for a audigy on win95.
Reply 12 of 12, by chinny22
_StIwY_ wrote on 2023-05-15, 15:09:
Pretty much, Think of it as Live! version 2
Biggest difference is you get EAX 3 support. (Live! is limited to EAX2) in theory it should sound cleaner/better but not sure if this is noticeable in the real world.
Windows drivers are also a little less boated.
For dos I doubt anyone will notice any difference between the 2 cards.
