First post, by JimLarimore
I have recently been working on getting the PCJr version of "Jumpman" to work in all its 16 color glory. The problem is that the game is checking for PCJr. bios, and if a positive is returned, the game will attempt to set video "Mode 8" which to my understanding is a 16 color 160x200 resolution mode that was unique to the PCJr. This mode was apparently not supported past the PCJr (who knows why).
I can modify the game's source code to always return a positive bios check, but that does not change the fact that current computers/video cards (or even a 386 as DosBox emulates) do not support this video mode. Is there any chance that DosBox could be modified to support this video mode?
Yes, I know you guys are trying to emulate a 386 not a PCJr, but I really do not see what harm would be in supporting a video mode that was fairly well used and then abandoned for no good reason. Fix the mistakes of yesteryear!
-Jim
Reply 1 of 20, by zorach
IIRC, this mode was fully supported by the 6845 CRTC used in the CGA; in fact I think you could even get it on a CGA, but you had to set up the mode yourself (as there was no BIOS support). I was always tempted to go digging through my Beeb's MOS to dig out the setup info and see if I could make it work on the PC, but didn't dare risk the damage to my card and monitor.
Confusing the issue: it appears the Herc's high-res mode was also mode 8. Shouldn't be a barrier to DOSBox given that there's already the "machine type" option.
Reply 3 of 20, by jal
Sorry, you're wrong on that. You mean the 160x100 16 color textmode, not the PCjr 160x200 graphics mode.
JAL
Reply 5 of 20, by jal
Well, there is no "past PCJr", that's why. The PCJr is an evolutionary dead end, although the Tandy "clones" took of quite wel in the US.
No, since it's already supported 😀. DOSbox has PCJr support, but it's called "Tandy" support. I'm not sure what BIOS check your game uses, DOSbox might even run an unpatched version if it does a BIOS call.
DOSbox tries to emulate a PC, in all its varieties, including PCJr/Tandy. I'm pretty sure that's also listed on the website.
Well, if it wasn't supported yet, lack of time would be a good "harm". Remember DOSbox is a volunteer project, and supporting a new type of videocard is not exactly easy!
It was abandoned for a very good reason: EGA/VGA. A couple of years after the release of the Tandy 1000, EGA/VGA became mainstream and there was no point in continuing an "inferior" card (EGA already had more capabilities than PCJr/Tandy, VGA improved even further).
JAL
Reply 6 of 20, by JimLarimore
So even after setting the machine type to Tandy the game will not run in 16 colors at 160x200. The screen just turns black. Are you guys sure the S3 or whatever card you are emulating is capable of displaying this video mode?
Reply 7 of 20, by zorach
No, I mean the 160x200 graphics mode. The 6845 *did* support it; the CGA BIOS did not.
Reply 8 of 20, by jal
Well, the 6845 is rather versatile, as it was used for both the Hercules and CGA. However, it is mainly concerned with the control of the CRT, not with the memory layout (banking etc.) and the color producing, afaik. I'm not sure whether the 6845 potentially can do a 160x200 graphics mode - I wouldn't be surprised if it could - but CGA cannot. This has little to do with BIOS: even when directly programming the hardware registers, it cannot be done.
JAL
Reply 9 of 20, by Harekiet
Rank DOSBox Author
DOSBox Author
The CGA 160x200 graphics mode was only through enabling the color burst bit and using the composite ouput, on the regular screen you just saw 640x200
Reply 10 of 20, by jal
True, I forgot about the infamous composite mode 😀.
JAL
Reply 11 of 20, by Great Hierophant
Unfortunately there is no way to do a RGB 160x200 mode on a standard CGA card, despite the fact that the CRT controller had no problem with it and the 16KB of memory on the card could contain it. Otherwise someone would have found it by now.
Reply 12 of 20, by jal
Yeah, well, that's what I said already 😉. It is unfortunate though, but understandable from IBM's point of view: they were making a business machine, not a games computer. Their version of the home computer, the PCjr, corrected this (but introduced many stupidities making it fail hopelessly).
JAL
Reply 13 of 20, by taiken7
If you can provide a 'working' executable, I can add support for the videomode.
I'm also interested in the PcJr bios test -- I should probably
address that as well, since other programs may make use of it.
Reply 14 of 20, by JimLarimore
Here you go. Attached is "Jumpman" for the PCJr. in all its glory. Within the attached zip is the executable and the source code if you want to take a look.
-Jim
    Jumpman.zip
    151.99 KiB
    218 downloads
    Includes working executable and the source code.
Reply 15 of 20, by JimLarimore
BTW this is completely legal as the guy who wrote this game worked for a company called Epyx who at the time had a clause in its contracts that seven years after the game was marketted, ownership of the rights would be transferred to the author. So, the original coder owns the rights to the game and has given his blessing to get this thing working on modern systems.
-Jim
Reply 16 of 20, by robertmo
when i set machine=cga and choose composite monitor in game i have at least 9 colours: white, yellow,orange,red, gray(robot's hands), light green, dark green, dark blue, violet and (black)
    2.02 KiB
Reply 17 of 20, by taiken7
Thats almost exactly what PcJr setup does.. good work there Rob 😎
(it tweaks CGA registers / selecting composite-tv output)
Ok, so now the other easter egg is the groovy tunes -- still not sure
how to get these going, it seems if you hard code a few things others break; dosbox freezes at 'Query_Joystick' following --
search replace "26803EFEFFFD 74 1D" with "26803EFEFFFD EB 1D"
ie 0:3E0d5 = was "74" now "EB" (mnemonic "JE" becomes "JMP")
