First post, by Beauty_Karova
Hi !!!
I tried to run BaK for a long , very long time with my WinXP...and finally I tried with dosbox.But it said me that I don't have enough memory to run the game (344464 bytes free)
Then I tried different things:
1 - I made a line in config.nt file ( EMM=RAM) in order to use all the extended momory .... nothing
2- I went into Krondor.exe properties and changed EMS and XMS into automatic ... nothing
3 - I made a boot floppy ...NOTHING
help me , I don't know what to do now 🙁 🙁
Ps : i downloaded the 0.63 dosbox version
Reply 1 of 6, by MiniMax
Rank Moderator
Moderator
Topic 2951
_________________
Reply 2 of 6, by Snover
Thanks MiniMax. Moving to DOSBox forum, even though I'm guessing there's a dupe somewhere...😀
Yes, it’s my fault.
Reply 3 of 6, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
BAK runs ok in DOSBOX. It can just take a bit longer to start (I think I heard that it zeroes all available EMS).
Anyway, you are confusing two things: DOSBOX settings are determined by DOSBOX.CONF. When a program is run in DOSBOX it does not have anything to do with CONFIG.NT or shortcut properties !!!!
Check that you have EMS allowed in DOSBOX.CONF and that you configured the sound properly.
Mirek
Reply 4 of 6, by Beauty_Karova
Sorry if i took the post in a wrong place : i didn't know if the problem was with dosbox , the game or my computer 😕
And I still don't know.
Mirek , thank U but I aready tried what you suggested .Still saying "not enought memory to run the game..." depressing !!!
Reply 5 of 6, by Beauty_Karova
YAHOOOOOOOOOOOOO !!!
Bak is working with DosBox 0.62 !!!! ( Still don't know what was theproblem with the 0.63 version but it won't prevent me from sleeping 🤣)
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
I just tried it with 0.63 with default settings.
Works fine.
Water flows down the stream
