Reply 40 of 985, by xjas
This isn't worlds best video, but I was messing around & just wanted to share. Not too bad! I would've played this if it was what I had in 1993.
https://drive.google.com/file/d/1KMYSZfvCMHg9 … iew?usp=sharing
Fastdoom 0.4, 386DX/25, Cyrix FasMath 387, Tseng ET4000AX, Opti sound card, kinda cheap board with no cache.
Quake gets 1.1 FPS on the same system. 😜 Even vanilla Doom isn't really playable.
Reply 41 of 985, by HandOfFate
I used to play Doom on a 386 SX 25MHz (after we finally upgraded to 4MB(!) of RAM). Unplayable without cheats but still cool. Does the shotgun reload animation lag behind the sound for you too? I always thought it funny: hear boom, hear click-click, (delay), see click-click 😜
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 42 of 985, by leileilol
ViTi95 wrote on 2020-08-04, 13:11:
PS I'll bring back gamma correction support in the next version of FastDoom 😁
Yeah I can only seeing this happening to the palette and the tint lumps on load (cached in memory), and reloading them with new processing on F11 press. unless that's what doom already did (I know quake throws all current palette data through a gamma lookup immediately on change per frame - definitely slow, and quake doesn't have any pre-calc'd tint lumps unlike doom)
long live PCem
Reply 44 of 985, by xjas
^^ neat! Hell of a lot more fluid than my 386. I don't know how much of that is CPU & how much is new optimizations, but I'm willing to bet my ET4000 wipes the floor with that OAK VGA card, at least.
Reply 45 of 985, by DracoNihil
ViTi95 wrote on 2020-08-06, 20:24:
New development video (FastDoom 0.5)
https://youtu.be/khVLctBY1GA
Curious, why the "age restriction"? There's plenty of videos of Doom that don't have that stretching as far back as 2007...
That option makes it impossible to watch the video anonymously without a user account involved which is what I typically view videos as. I only ever use my account to upload videos and change settings on videos Twitch exports because Twitch's system auto-inserts things I don't want auto-inserted.
― Κυνικός Δράκων
Reply 46 of 985, by root42
Wow, what a cool project! I will have to try this out on my 486DX33 with the ISA ET4000. The 80x200 is neat. Are you using Mode Y and writing to all bitplanes at the same time?
YouTube and Bonus
Reply 47 of 985, by ViTi95
xjas wrote on 2020-08-06, 20:50:
486 processors are way faster than 386 due to the inclusion of the L1 cache, it's normal to run faster Doom in those processors. Having a fast video card it's important in Doom, but it is much more important to have a fast processor with lot's of cache (L1+L2).
DracoNihil wrote on 2020-08-06, 21:21:
Well the age restriction is gone, I didn't know how Youtube age-restriction policy worked really (so i avoided problems by restricting directly the content)
root42 wrote on 2020-08-06, 22:00:
Yes, Potato mode writes all the planes at the same time, using the same idea as the Low render quality mode. Write 1 pixel and you get 4 drawn, it helps a lot old ISA VGA video cards that have very limited bandwith. Even 8 bit ISA VGA cards run well in Potato mode.
EDIT:
Previous DEV build running on a 386SX
https://youtu.be/qDqr8cYOeOE
https://www.youtube.com/@viti95
Reply 48 of 985, by DracoNihil
Potato mode might as well be SNES Doom mode, that's the huge vibe I get from the graphics looking that way.
Were you using a GUS for music in that video?
― Κυνικός Δράκων
Reply 49 of 985, by leileilol
Maybe Fastdoom could have the old scrapped "2MB RAM support" idea of loading only 3 generic sounds commonly applied to everything (Gun fire, Death OOGH, Door swish), as seen in the Nov 93 "A visit to id software" video
For all those potato fans (and haters that don't get the point), a reminder that Dark Forces had such a mode
    8.68 KiB
long live PCem
Reply 51 of 985, by HandOfFate
DracoNihil wrote on 2020-08-06, 23:54:
I think that card is an AWE64 Value
Reply 52 of 985, by Garrett W
leileilol wrote on 2020-08-07, 00:23:
I had no clue Dark Forces had a "potato mode". Is this achieved by lowering the detail within the game or is this some sort of command line switch? I don't remember the in-game options lowering the details that much!
Reply 53 of 985, by Oetker
Garrett W wrote on 2020-08-10, 12:20:
Yes you can limit the in-game detail to Atari 2600 level.
Reply 54 of 985, by ViTi95
HandOfFate wrote on 2020-08-10, 11:10:
You're right, it is an AWE64 Value. GUS support is problematic and I'm trying to fix it.
Reply 55 of 985, by DracoNihil
ViTi95 wrote on 2020-08-10, 20:00:
Man I'm dumb, yeah. It's hard to tell the difference between the AWE's ROM and the default GUS patch set.
I hope GUS support doesn't prove too impossible to fix, it never really worked properly in Doom at all because of DMX shortcomings.
― Κυνικός Δράκων
Reply 56 of 985, by ViTi95
New release!
https://github.com/viti95/FastDoom/releases/tag/0.5
Changelog:
  • Faster Potato mode. Now it's 100% native potato mode and doesn't use the LQ mode to draw the screen.
  • Fixed Sega Saturn shadows in potato mode.
  • Added "-init" parameter, it forces the user to press a key to start the game. This makes easier to see the initialization process.
  • Now it's possible to use "-nomonsters" without "-warp level". Change made to test the IA performance impact.
  • Fixed AWE32 music.
  • More rendering and main code optimizations.
  • Bring back the gamma correction, lot's of users with CRT monitors needed this functionality (F11 key)
  • Remapped autorun to F12 key
Reply 57 of 985, by HandOfFate
Cool, I'll be sure to try it out (once my computer room is below Hell temperatures). I'm curious to see if the FPS has improved even more, compared to my earlier benchmarks.
What do you mean with Sega Saturn shadows? Was there something bad about the shadows in the that port?
Reply 58 of 985, by ViTi95
HandOfFate wrote on 2020-08-13, 16:41:
The implementation I made of the Sega Saturn shadows in FastDoom wasn't right while potato mode activated. The rendering was just wrong.
Reply 59 of 985, by xcomcmdr
ViTi95 wrote:
Fixed AWE32 music.
I finally brought back online my PIII desktop retro PC a few weeks ago, and it has an AWE64 value inside it. Perfect timing !
