First post, by Shocked_
Hello!
This is my first post here. I bought the game for Christmas to my brother and I'm goddamn embarrassed because I can't get it working. Everybody thinks I'm the computer nerd of this family.
System: WinXP SP1, 32mb GeForce 2, 750MHz Duron
Ok, this is the problem: Game freezes right in the beginning. I double click worms.bat and game starts only to freeze almost right away. In the screen there is a level. The ocean waves few times and then it stops. I cant do anything but press Windows key and shut game down. Then my cdrom drive refuses to open and Worms theme music starts playing. That is without DOSBox.
WITH dosbox I get, after mounting C:\Worms and my cdrom drive with basic mount, a screen which says http://koti.mbnet.fi/~juzzi85/_salaiset_arkistot/1st.png. I wait and wait... nothing happens, I hit s key and I got this screen: http://koti.mbnet.fi/~juzzi85/_salaiset_arkistot/2nd.png.
Could you help me? I refuse to believe that Worms doesn't work WinXP! SP2 is not an option... Too many old games stop working with that. I've also tried compatibility modes and VDMS with no luck.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
seem like you have mounted it incorrect.
as it can't find certain files.
Water flows down the stream
Reply 3 of 3, by Snover
Dude, Service Pack 2 does not break anything more than Windows XP itself does. If you disable the NX protection, most things that SP2 breaks will probably start working again (self-modifying code is the devil).
That said, SP2 is rather completely irrelevant to this problem.
Try mounting the CD as such:
mount d d:\ -t cdrom -ioctl
Yes, it’s my fault.
