First post, by iVirtualZero
I’m thinking about delidding my Tualatins. Has anyone dellided them? What tool shall i use? And is it worth the effort?
Reply 1 of 20, by Marentis
It depends on what you want to do with it. I'm assuming this is about overclocking?
In that case it would probably be a good idea to know how hot your CPUs run currently to see if it might
give you any benefit in that regard as there's always a risk in doing so.
Here another overclocker has delidded his Tualatin even with pictures showing the process:
https://forums.overclockers.com.au/threads/pe … -delid.1136735/
Reply 2 of 20, by Socket3
Is there any point in delidding a tualatin? They don't really generate much heat... As for overclocking, as far as I can understand max clocks are limited by the manufacturing process and architecture, not by thermals or power. Please correct me if I'm wrong.
Reply 3 of 20, by Marentis
To be fair, temperature *can* limit your overclocking capacities if the CPU either gets damaged, unstable or - as more modern CPUs do - starts throttling to prevent damage.
Then again, I wouldn't overclock older systems because that puts extra stress on components with very limited supply and modern systems are very effective
at handling their own clock rates. But each to their own and if the OP loves overclocking, so be it 😀.
Reply 4 of 20, by The Serpent Rider
Quality of VRM, voltage and cooling improve overclocking. Cooling below zero Celsius can drastically improve overclocking potential.
Overclocking without voltage increase rarely puts any significant stress on hardware.
Reply 5 of 20, by dr_st
Socket3 wrote on 2020-08-08, 11:29:
Like everything, the point is to destroy working hardware (the rarer - the better) for the purposes of "testing" only-God-knows-what.
Take it from the masters:
Re: Delidding an SL7CH CPU? (socket 478 P4 EE)
Reply 6 of 20, by Socket3
dr_st wrote on 2020-08-08, 19:22:
Like everything, the point is to destroy working hardware (the rarer - the better) for the purposes of "testing" only-God-knows- […]
I can't believe he delidded a Gallatin. And worse, it was soldered so now it's dead. I'd give my left nut for a working P4 EE, either socket 478 or LGA775. P4 EE are pretty much unicorns in my neck of the woods, and both price and shipping prohibit me from purchasing one... It pains me when I see someone destroy one of these babies.
Reply 7 of 20, by cyclone3d
Socket3 wrote on 2020-08-10, 15:03:
I got my Gallatin EE CPUs for a really good price. Just have to wait and watch until they pop up for a good price. It doesn't happen very often. The normal prices I see them going for on eBay is just insane.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 20, by Socket3
cyclone3d wrote on 2020-08-10, 15:17:
They do come up once in a while, but all I've come across so far have been from the US, witch means insane shipping costs.
Reply 9 of 20, by computerguy08
I accidentally delidded my Northwood Celeron when I tried to remove the cooler form a Socket 478 laptop. There was no room to wiggle the cooler, so I was forced to pry it out. The CPU stayed in the socket, while the IHS was stuck on the cooler. Thankfully, it used thermal paste under the IHS instead of solder.
As for the topic itself, delidding any CPU is a really stupid idea IMHO. If you really want to overclock those old CPUs, you're better off using watercooling (or even LN). The benefits of replacing the thermal interface under the IHS are simply not worth it over the risk of permanently damaging the CPU.
Reply 10 of 20, by The Serpent Rider
You can't damage Tualatin by simple delidding and changing thermal interface between IHS and crystal after 20 years also won't hurt...
Basic razors should suffice. Just carefully and slowly cut glue between CPU PCB and IHS. You probably would want to add silicon pads similar to Athlon CPUs after that.
Example: Re: Socket 939 FX-60/Opteron 185 cooler recommendation for 110W TDP
Reply 11 of 20, by RoberMC
The thermal interface between the die and the heatspreader is usually less efficient than toothpaste in this 20 years old CPUs. That may affect their longevity, even at stock speeds.
I usually delid the CPUs i care the most, replace the old paste with the higher quality interface i consider suitable (Liquid Metal or traditional high performance paste), and then reasemble the CPU just like it was before, using same color adhesive and stuff.
I try and overclock them just for fun and see how far they go, but i use the stock clocks for daily use. There is no point in use an overclocked PIII when you can build a more powerful machine for peanuts if you need it.
An advice to anybody who want to remove a heatspreader, use a VERY sharp and thin razor blade, knifes and cutters are not as sharp as i would consider suitable. the sharper and thinner the easier the work, the easier the work = less probability to damage the CPU.
Reply 12 of 20, by The Serpent Rider
PIII platform is easiest choice to assemble a powerful retromachine with ISA slot and overclocking won't hurt for highres DOS gaming.
Reply 13 of 20, by slivercr
I have delidded Tualatins. It allows them to use any CuMine heatsink without bending any bracket.
P3-s 1400 may be uncommon, but Tualatin as a family is definitely NOT rare.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 14 of 20, by jm764
I recently delidded a broken Tualatin Celeron 1300 I have, and if it weren't for the fact the pins were broken underneath before, I definitely would of destroyed it from how harshly I "scraped" the IHS glue off. 😅
Regardless, it's definitely worth it for both temps and cooler compatibility as it allows massive AMD Socket 462 coolers to fit on them as well. 😉
So to anyone else who wants to do this, just be REALLY CAREFUL while doing so, otherwise you may cut into the substrate/traces as it's pretty thin.
Also you technically could do this to Socket 423 Pentium 4's, but given their "hybrid designs" (Basically a mix between a Socket 370 Pentium and a later Socket 478 Pentium 4 mounted on top of that), I doubt anyone would even try let alone do it successfully.
Reply 15 of 20, by cyclone3d
Anybody remember when you could get 15-20c load temp drops by de-lidding a Socket 939 Athlon 64 or Opteron series CPU? I do. I still have my Opti 175 that I de-lidded soon after I bought it new.
Before that I de-lidded some K6-2 CPUs.
The trick is to not cut the glue by sliding the razor back and forth, but to just sit the razer where you want it and push it through . You also don't have to cut the glue the whole way around. After enough of it is cut, the heatspreader will be able to be gently pulled off. Way less risk of damaging the CPU by doing it that way.
YMF7x4 Guide
Reply 17 of 20, by VooDooMan
Yes, just once and It was not on purpose... just and accident! 😁
    179.65 KiB
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 19 of 20, by VooDooMan
I've already done some overclocking without delidding 😁 Re: Overclocking Pentium III / Celeron: Coppermine and Tualatin cores - Socket 370
