First post, by NyLan
Hi,
I bought this card recently with a slot1 PIII 500Mhz. As I didn't found lot of info for this Motherboard or posts here, I'm posting my experience 😀
So I put a slot1 PIII 850 and it was not correctly recognized ( but working fine )
Seems Matsonic was not using bios revision number, just the date of the release... I flashed a newer Bios and now the CPU is correctly recognized. For some reason I can briefly see a "Unknown Flash Type" when the computer starts, but no issues to report.
Attached file below :
The Bios I had : 10/25/99 ( Checksum 0B4DH ) - Filename Old.BIN
The Bios I flashed : 06/30/00 ( Checksum CB9EH ) - Filename 06302k.BIN
Had to use Awdflash 6.6
Also attached the manual
    ms7112c.pdf
    1.2 MiB
    38 downloads
    Manual
    Matsonic.zip
    305.51 KiB
    33 downloads
    Bios
    awdflash66.exe
    24.44 KiB
    32 downloads
    Flash tool
    1.67 MiB
    Motherboard
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
