First post, by mvz
I've completed setting up a HP T5710 Thin Client with MS-DOS 6.22
Everything works a charm, including SBPro using VIASBCFG / FMTSR.
The problem arises when I try to use a mouse in conjunction with a keyboard.
As soon as the mouse is thrown into the mix, keypresses on the keyboard get stuck and you keep moving in the direction you were going.
Opening 'Edit' in MS-DOS and moving the mouse while depressing any key combination on the keyboard, shows the cursor jumping around eratically.
It does not matter which mouse driver I use, CTMouse, Logitech they all behave similarly.
Does anyone know whats going on? Is the poor machine chocking on too much input?
I've since ordered a serial mouse, which is on its way. I will let you know if that works better once it arrives.
collector wrote on 2020-08-31, 17:59:Wrong forum. This forum is for DOS games on modern systems. Ask old hardware and driver/configuration questions in Marvin. Marvin, the Paranoid Android
Understood, the HP 5710 thin client isn't exactly old hardware for MS-DOS though..
