First post, by dr.zeissler
Hi there, I am a bit confused about my Acer V66LT Board with ATI 3D Rage Pro LT.
Are there drivers for Win3x? I could not find them and the WFW3.11 Vesa 256Color-Driver does not work too ;( (corrupted screen)
Beside that I am wondering why in win9x there is only D3D but not OpenGL-Support.
What drivers should I use, especially if I would like to play some really old "ATI3DCIF" stuff too.
Thx!
Doc
RAGE LT (laptop) and RAGE LT Pro (desktop)[edit] […]
Rage LT chip
ATI Rage LT Pro AGP, 8 MB SDRAM
Rage LT or Mach64 LT was often implemented on motherboards and in mobile applications like notebook computers. This late 1996 chip was very similar to the Rage II and supported the same application coding. It integrated a low-voltage differential signaling (LVDS) transmitter for notebook LCDs and advanced power management (block-by-block power control). The RAGE LT PRO, based on the 3D RAGE PRO, was the very first mobile GPU to use AGP.
It offered Filtered Ratiometric Expansion, which automatically adjusted images to full-screen size. ATI's ImpacTV2+ is integrated with the RAGE LT PRO chip to support multi-screen viewing; i.e., simultaneous outputs to TV, CRT and LCD. In addition, the RAGE LT PRO can drive two displays with different images and/or refresh rates with the use of integrated dual, independent CRT controllers.
The Rage LT Pro was often used in desktop video cards that had a VESA Digital Flat Panel port to drive some desktop LCD monitors digitally.
After ATI stopped producing the RAGE LT, ATI used the Rage 128 and Rage 128 Pro as the base chip for their new Mobility Mobile Graphics.
german: http://www.vdr-wiki.de/wiki/index.php/Beispie … n_-_Scovery_250
Reply 2 of 27, by dr.zeissler
ATI3DCIF.DLL collection http://vogonsdrivers.com/getfile.php?fileid=498&menustate=0
Rage LT Pro fully supported from 4.10.2661
https://gona.mactar.hu/ATI_3D_CIF/#Severe
MechWarrior 2 and TombRaider are working on Rage LT Pro up to 4.11.2573 (MACXW4)
2661 vs. 2573 ? strange? Higher versions 26xx seem to break everything on ATI3DCIF?
http://www.oocities.org/ziyadhosein/rprow98.htm
But higher versions do have an opengl driver ? So I am stuck in a compatibility dilemma?
Doc
Reply 4 of 27, by dr.zeissler
This is the driver I am using. It has opengl-icd included and it works in D3D too.
http://cwcyrix.nsupdate.info/ftp-archives/ftp … 000/SP10912.EXE
I have to try ATI3DCIF next!
Interestingly my OSDM files do work (if DX7 is loaded), that was pretty unexpected...
Reply 7 of 27, by dr.zeissler
One thing is the very bad image quality on textures in opengl on that ATI-Rage-Pro LT...
and also some textures "alpha" are not filtered and look blocky...
Doc
Reply 8 of 27, by dr.zeissler
Hm, win3x does not work on Rage Pro LT... I only can use VGA 640x480@16colors.
If I choose SVGA 256colors the screen is currupted and I see only some lines on top of the screen.
If I install the mach64 win3x drivers I only get some moving lines on the screen...so that is pretty bad because a r7000 works just fine with svga-drivers.
Any Idea what I can do to get 256colors in Win3x?
Reply 9 of 27, by matze79
Mach64 Driver does not work on Rage Pro, it should work on pre "Rage Pro".
Rage II, Rage I, Rage IIC etc.
Reply 11 of 27, by Giuliano
There is one wild idea. Would it be possible to install Windows 2000 on that machine? I think there are proper W2K drivers for ATI 3D Rage Pro LT (to be checked). Then, you could use Virtual PC 2004 to install Win3x, and get 24-bit color thru the emulated S3 Trio64 video card.
Reply 12 of 27, by dr.zeissler
Interesting idea, but the machine will be too slow for that...but I think I can patch the WFW-Drivers with vesa, so it should work...I'll test this in the next weeks. Currently working on my G4-Cube.
Reply 13 of 27, by dr.zeissler
The ATI Rage Pro LT has dramatic slowdowns eg. in the Intro of Turok1. Beside that the chip lacks bilinear filtering.
But I sometimes like the "software-acclerated" look in some games. I am currently thinking about a powervr addon-card for it.
Reply 15 of 27, by Putas
dr.zeissler wrote on 2020-12-03, 09:56:
Something is wrong then.
Reply 17 of 27, by dr.zeissler
dr.zeissler wrote on 2020-12-03, 14:49:
I don't think so.
https://vintage3d.org/rage3.php
    74.74 KiB
Reply 18 of 27, by dr.zeissler
Putas wrote on 2020-12-03, 13:31:
You are right, using the D3D driver on Turok does help. The D3D driver does not suffer from the dramatic slowdowns the custom "rage-driver" shows in turok. But the image does not look as nice as 3dfx does (even if 3dfx is blurry). The rage-pro does not do bilinear-filtering on alpha-channel, or whatever this is called. I am currently thinking about putting an R7000-PCI in that thing...
