First post, by sangokushi
My friend helped me to buy an I/O DATA PCJOY PCMCIA Gameport from Japan several month ago. I was under the assumption it works in DOS.
Recently when I tried to install the driver in DOS, it show an error English DOS not supported.
Installing in Windows 98 also error out with Windows 98 files not found.
After further research, it seems DOS/V is required. It's DOS with Japanese (doublebyte characters) support.
Windows 98 probably also needs Japanese version.
Here is the driver:
http://nwserveur.no-ip.org/win3xorg/devices/P … 0PCJoy/drivers/
Anyone knows if there is a work around, so I can install on English DOS?
Reply 1 of 11, by Warlord
you might want to try a non official driver for the device. As in a driver for a different PCMCIA game port card. This is under assumption it just uses some kinda standard gameport interface.
Try find EXP game traveler drivers from archive and see if they work
https://web.archive.org/web/20031102114950/ht … 30&Expand=12#12
https://www.driverguide.com/driver/detail.php … driverid=428383
Reply 2 of 11, by lolo799
sangokushi wrote on 2020-09-28, 22:20:
My friend helped me to buy an I/O DATA PCJOY PCMCIA Gameport from Japan several month ago. I was under the assumption it works i […]
Here is the driver:
Don't run the install.
Just use JOYDV.COM enabler on the commandline, you might need Cardsoft Socket and Card Services running if your PCMCIA chipset isn't PCIC compatible.
1.73 KiB
2.03 KiB
Reply 3 of 11, by sangokushi
Warlord wrote on 2020-09-29, 06:07:
you might want to try a non official driver for the device. As in a driver for a different PCMCIA game port card. This is unde […]
@Warlord It seems the EXP drivers only work for their hardware.
In Windows 98, it detects PCJOY and prompts for driver, browsing the EXP driver folder results Windows cannot find driver for this device.
In DOS, add EXPGAME.EXE to config.sys and reboot shows "pcmcia game card is not present!"
Reply 4 of 11, by sangokushi
lolo799 wrote on 2020-09-29, 09:28:
Don't run the install. Just use JOYDV.COM enabler on the commandline, you might need Cardsoft Socket and Card Services running […]
Here is the driver:
@lolo799 Installed Cardsoft Socket and Card Services. Loaded JOYDV.SYS in config.sys without error
Also ran JOYDV.COM without error
However, when I run Street Fighter, the game cannot detect joystick. There is a JOYTEST.EXE, and it said cannot run in US (I assume it means English)
    1.04 MiB
    1.14 MiB
Reply 7 of 11, by MAZter
Just ran JOYDV.COM with PCJOY2 and Street Fighter works fine as well as other games. I tried with PC Propad 4 and Interact ProPAD, so this could be Gravis issue? Are you sure, that your gamepad works?
Doom is what you want (c) MAZter
Reply 8 of 11, by sangokushi
MAZter wrote on 2020-10-01, 03:25:
I will order a PC Propad 4 and retest. Do you mind to share which laptop you test with PCJOY2?
Reply 9 of 11, by Bondi
My Gravis gamepad worked with PCJOY2 in DOS on IBM TP 360c. AFAIR it did not even require SS and CS.
What laptop are you trying it on?
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 11 of 11, by MAZter
sangokushi wrote on 2020-10-01, 04:11:
Toshiba Tecra 8000, or Samsung Sens 800
Interact ProPad Blue is awesome with Dangerous Dave!
171.75 KiB
