First post, by fsmith2003
I have a Pi 3B+ that I am trying to use MT32-Pi on. Are there step by step instructions other than what is on the quick start section of the creators github? I followed those and nothing is working. Here is what I did:
- I copied the contents of the zip file downloaded from the github page onto the root of the Pi's sd card.
-I placed the MT32 roms in the roms folder of the sd card
-I plugged in the UM-One into a USB port of the Pi and plugged in speakers to the headphone jack.
-I hooked up the other end of the UM-One to my vintage PC's midi port.
- When turning on the PI none of the LED's light up on the UM-One and there is no sound coming out of the speakers when playing midi from the vintage PC.
-I confirm this same setup works using Munt on a regular PC without the pi so I know the configuration is correct on the UM-One cable itself.
Anyone using this same configuration and have some hints of how to get it to work?
Reply 1 of 17, by FISHERMAN
i am stuck in the exact same position on a RPI3A with UM-ONE cable ..i have send an email to Edu Arana asking for some clarifications.
following the instructions from github i did some changes :
usb = on
gpio_baud_rate = 31250
gpio_thru = off
output_device = i2s --> no output 🙁
sample_rate = 96000
chunk_size = 512
i2c_dac_address = 4c
resampler_quality = good
midi_channels = standard
rom_set = old
type = ssd1306_i2c. --> oled screen now working OK
if i use a simple Midi cable then on the oled screen i get the messages "frame error" & "Midi unexp error" and sound is distorted , while if i change to UM-ONE cable i get no sound and no messages on screen..
I also confirm that running rpi3b+ with muntPi worked pefectly with the same pc setup and um-one cable.
Reply 3 of 17, by Jo22
MT32Pi is really neat. I tried a cheap USB cable on the reception side first, but soon realized that the MIDI interface was poor - no opto-coupler, just resistors (bad design!).
Because, with different ground connections, this setup almost begs for a failure.
So I made a cheap MIDI-In using an underpowered, slow opto-coupler and finally got music in Gateway.
Here's a quick video of it, along with a cheap tube amp that I made from spare parts.
If done correctly (fast opto-coupler), the little stuttering should fixed, too :
https://m.youtube.com/watch?v=Y43kYMGZhKk
    240.44 KiB
    285.12 KiB
Reply 4 of 17, by gdjacobs
FISHERMAN wrote on 2020-10-17, 21:47:
i am stuck in the exact same position on a RPI3A with UM-ONE cable ..i have send an email to Edu Arana asking for some clari […]
usb = on
gpio_thru = off
sample_rate = 96000
chunk_size = 512
rom_set = old
Do you have an external DAC? I2S will output serial data via the requisite pins and needs an external device wired to the GPIO header to decode it.
Reply 5 of 17, by Jo22
Is that Roland cable correctly connected?
Re: Roland MT-32, CM-32L + General MIDI for $50 Building a MIDI box
Reply 6 of 17, by FISHERMAN
Finally I was not doing anything wrong ....updated to o.62 and voilas!! Happy gaming
Reply 7 of 17, by Jo22
FISHERMAN wrote on 2020-10-24, 20:35:
I can confirm, no lame excuse.
USB MIDI was broken for a moment (6 to 6.2).
Reply 8 of 17, by fsmith2003
Everything is working great now! I did just obtain a 128x32 LCD for the Pi. It is working great as well but it did cause me to notice one thing. It shows the volume is set at 72 within MT32-Pi. Is there a way to adjust this in the config file or otherwise? I have noticed the volume is much quieter coming from it than my other computer sounds from the sound card.
Reply 9 of 17, by Spikey
The MT-32 has a low volume output, so increasing from 72 to 100 will likely help, but not enough (28/72 = ~40% louder than currently) . If it's based on MUNT, maybe you can enable gain?
Reply 10 of 17, by d0pefish
Hi, I'm the author of mt32-pi.
Sorry about the broken USB; it doesn't get tested as often as GPIO MIDI so unfortunately I missed it!
Re: the volume - it should always be 100 when you first boot up. Some game/MIDI song will have lowered it via a SysEx message, I imagine.
The volume will be controllable via a rotary encoder soon.
US1wUaR.pngg
💾 Download | 📚 Documentation | Support
Reply 11 of 17, by fsmith2003
d0pefish wrote on 2020-11-01, 15:10:
Hi, I'm the author of mt32-pi. […]
Yes I did notice it was 100 on start up but most games will lower it themselves. A manual rotary knob would be a great addition!
Reply 12 of 17, by Jo22
Hi - Thanks a lot for browsing by and for your help! 😎
I'd like to take the opportunity to thank you (in the name of many here, I guess) for the excellent work.
Even though I'm one of the few people who own both a MT-32 and a CM64, I have a lot of fun tinkering with MT32-Pi and my Raspberry Pis.
I'm currently doing a little project that involves installing a Raspberry Pi (w/ MT32-Pi) in the chassis of an old alarm clock.
When I tried running it on a Pi 2, nothing happend at first, but it was my fault. 😅 My USB MIDI interface was plugged in another port,
so the MIDI I/O in Raspbian changed. Editing my DOSBox config and changing "midiconfig=24:0" to "midiconfig=20:0" fixed it.
Edit: Setting chunk size to 256 and disabling resampling seems to improve music playback on the Pi 2 in my copy of Frederik Pohl's Gateway.
IMHO, I think it is very cool that MT32-Pi still runs on the old Pi 2. Even though doing so is on the very limit (almost borderline).
Because, the Pi 3 has a power managment chip that easily breaks if 3.3v line gets a short (on the GPIO).
So an used, second-hand Pi 2 has a higher chance of functioning than a Pi 3, I assume.
Also, some late Pi 2's seem to have the same ARM chip as the Pi 3 (speaking under correction, though).
Speaking of the Pi 2.. I use a not so quick opto-isulator on the GPIO interface, a CNY17-2 in diode-"mode" only to make things faster.
It's not ideal and I experience some stuttering, perhaps some buffering issues (resampler_quality = fastest).
It seems to me that changing to a CM32L ROM set reduces this stuttering a bit, but still causes hanging notes.
That being said, not sure if this really has an effect or if it is just my imagination.
I must check with a fast optocoupler next time, if I can get one (my local seller only has common types).
Anyway, that's enough I guess. I don't mean to hijack fsmith2003's thread. 😅
Just wanted to provide some feedback.
Reply 14 of 17, by CrossBow777
fsmith2003 wrote on 2020-11-01, 19:02:
Most Sierra games do this. In the game itself you have a volume adjustment and changing that should also show on the display for the MT-32 side of things. That is how it works on the actual MT-32 at least.
Midi Modules: MT-32 (OLD), MT-200, MT-90, SD-20
Reply 15 of 17, by Spikey
CrossBow777 wrote on 2021-02-23, 14:33:
I could be wrong, but I thought the volume adjustment changed the volume controller values, not the master volume? Maybe I'm thinking of GM games.
EDIT: Yeah, MT-32 games work how Crossbow said, and GM games work how I said. Interesting.
Reply 16 of 17, by HadriaGuy
Hi....I'm utilizing a Pi 3B+. I duplicated the substance of the zip downloaded for the most recent arrival of mt32-pi onto the foundation of the Pi's sd card and added the roms. I connected my UM-ONE to a USB port of the Pi and the opposite end into the midi port of my pc. With this set up in this setup I don't get and red light illuminating on the UM-One. When playing midi documents there is no solid at all to the associated speakers.
order pcb assembly
Reply 17 of 17, by fsmith2003
HadriaGuy wrote on 2021-03-10, 17:35:
Are you using the latest release of MT32-Pi? I was having the same issue because the initial version I was using had broken USB support which was later fixed.
