Tyan Titan-Pro AT/ aka S1662
First post, by Nexxen
Bios: TYN TITAN-PRO V5.01 5/8/98
Init string: 05/08/98-i440FX-2A69HT5JC-00
Bios in zip.
Bios rom on a Winbond W29EE011-15 (128kb).
Needs at least two sticks of ram to post.
http://www.win3x.org/uh19/motherboard/show/5107
https://web.archive.org/web/20010530211458/ht … l/b_tt_pro.html
ftp://ftp.tyan.com/manuals/m_s1662_100.pdf
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 1 of 34, by Nexxen
Voltage regulators:
Reply 2 of 34, by chinny22
please tell me your planning a build with that sexy thing
Reply 3 of 34, by Nexxen
chinny22 wrote on 2020-12-29, 13:43:
I'm looking for a case with enough space to host everything without the need of a smurf squad (not the Grouchy Smurf though he's always "I hate going in the narrow case!") to service it each time I need to put my hands in it.
Yes, long sentence! 🤣
I'd like to have a plexi or acrylic model. It must show how cute it is 😀
Reply 4 of 34, by chrismeyer6
I'm loving this build so far. I wish you good luck on your case hunt.
Reply 5 of 34, by Nexxen
chrismeyer6 wrote on 2020-12-29, 18:45:
Plexiglass AT case, I strongly believe none exists.
I could try to have one built but it could be quite expensive.
Reply 6 of 34, by chrismeyer6
Unless you get either a full size AT tower case or and AT server case and put a window in the side panel
Reply 7 of 34, by red-ray
Wow, P-II overdrives. Which OS do you plan to install? I would be interested to see how my SIV utility does and am wondering if the board SMBIOS information.
Reply 8 of 34, by Nexxen
red-ray wrote on 2020-12-31, 08:48:
Just tell me what OS would be best and I'll give it a spin.
Retro fun is retro fun 😀
Reply 9 of 34, by maxtherabbit
damn that's like a thousand dollars in that pic at ebay prices 🤣
Reply 10 of 34, by red-ray
Nexxen wrote on 2020-12-31, 14:33:
Just tell me what OS would be best and I'll give it a spin. Retro fun is retro fun 😀
Given the age of the board I am unsure if Windows 2000 will run well so would be inclined to start with NT4 SP6 and once that is running also install one of Windows 2003, XP or 2000.
I managed to also install both W2K + WXP on my system, but the CPU-1 cache ends up disabled whereas on NT4 SP6 it's fine.
How much memory will it have? With NT4 you can get away with 64MB, but more sill be needed for W2K and even more for WXP/2003.
Reply 11 of 34, by Nexxen
red-ray wrote on 2020-12-31, 14:52:
Given the age of the board I am unsure if Windows 2000 will run well so would be inclined to start with NT4 SP6 and once that is […]
Max Ram is 1024 in 8 slots, I have for sure 256 (8 x 32MiB). I have a lot of 32MiB only.
I can install NT 4 sp6 + 2K (sp required?) + Xp (sp required?).
Reply 12 of 34, by red-ray
Nexxen wrote on 2020-12-31, 15:05:
256MB should be fine. SIV should run OK with the W2K + WNT RTM releases, I know SIV was OK on W2K RTM a couple of days ago, but am unsure about WXP. My systems I tend to have W2K SP4 + security rollup, WXP SP3 and 2003 SP2.
What disk will the system have? I use an 17 GB SCSI drive partitioned as below. C: needs to be FAT16 as NT4 does not support FAT32.
Drives on my multi-boot system
[Volumes] <- SIV32L  - System Information Viewer V5.55 Beta-03 RDO::ray
Drive and Path Volume Label Format SIV32L Free Total Used Cluster Drive Type Volume Serial
[A:] 3½" 1.44MB |Floppy|
[C:\] RDO-C W310 FAT16 |G| 758.03MB 2.00GB 63% 32KB |Fixed| 1604-1F10
[D:\] RDO-D W351 FAT16 875.34MB 1.00GB 14% 16KB |Fixed| 2046-65D9
[E:\] RDO-E W400 FAT16 831.20MB 1.00GB 18% 16KB |Fixed| 3899-2EFC
[F:\] RDO-F KITS FAT16 265.44MB 2.00GB 87% 32KB |Fixed| 244E-B050
[G:\] RDO-G W500 NTFS 1.09GB 2.00GB 45% 2KB |Fixed| D4F4-1C1D
[H:\] RDO-H W501 NTFS 7.47GB 8.96GB 17% 4KB |Fixed| F80C-AF47
Total Floppy 0 (1) 0 0 |Floppy|
Total Fixed 6 (6) 11.22GB 16.95GB 34% |Fixed|
[ OK ] [ Copy] [Windows] [Machine] [USB Bus] [Network] [ SPD ] [ SMART] [Volumes] [Drive C:] [ NTFS] [ALL Dev]
Reply 13 of 34, by Nexxen
red-ray wrote on 2020-12-31, 15:23:
256MB should be fine. SIV should run OK with the W2K + WNT RTM releases, I know SIV was OK on W2K RTM a couple of days ago, but […]
Some IDE with W2K as directed then.
My next project is this.
Reply 14 of 34, by Nexxen
maxtherabbit wrote on 2020-12-31, 14:46:
Ebay is out of the world. I'd never buy at those pirces.
Edit: made a mistake "pirces" instead of "prices", sounds like "pierces"... Freud was right all along 😀
Reply 15 of 34, by Nexxen
Installed NT 4.0 Sp1 and would hang after a while.
Restarted in VGA mode and installed SP6a.
Had to restart in VGA mode again a set video resolution there and stopped hanging.
No USB. How do I?
Installing W2K SP4 now.
Reply 16 of 34, by red-ray
Nexxen wrote on 2021-01-03, 14:06:
No USB. How do I?
With NT4 Microsoft do not support USB, but there are 3rd party products, see https://nt4ref.zcm.com.au/. I suspect it's easier to install W2K.
I never really needed USB on my NT4 systems as they are all connected to my network.
Reply 17 of 34, by Nexxen
red-ray wrote on 2021-01-03, 14:21:
No USB. How do I?
I figured. If not OTB go to W2K, works fine and easy.
Reply 19 of 34, by PARKE
Nexxen wrote on 2020-12-30, 20:43:
The trend started after 2000 so little to no chance on an AT format.
It is however simple to mod a blind i/o backplate. Drilling some extra holes if needed is simple too.
Good luck finding a nice one - here some options:.
https://www.anandtech.com/show/1377
