First post, by Predator99
Just like to share I got my Vermont Microsystems IM-1024 PGC-clone to display a picture, but I am afraid to get more out of it I need some software or documentation.
Its this card:
72.15 KiB
730.12 KiB
208.13 KiB
I was able to connect to my DELL LCD without any adapter. Just connected 4 wires: RGB and composite sync to VGA-PIN13.
https://www.seasip.info/VintagePC/pgc.html
189.76 KiB
To lazy for GND which may explain the bad image quality I got 😀 But I am happy it displays anything at all without converters or adapters.
Resolution is always 1024x768 @ 60Hz.
Also happy it displays the BIOS screen, was not sure if this card works as a secondary adapter only.
CGA emulation also works.
With the PGCBMP.EXE programm I only get a purple screen but no picture is displayed.
There seems to be a Windows 1.0 driver around but its use is quite limited...
https://pcem-emulator.co.uk/phpBB3/viewtopic.php?t=3187
So if anybody owns a driver disk or a manual I would be very happy to get a copy...
Reply 1 of 2, by Predator99
230.08 KiB
481.28 KiB
404.13 KiB
Reply 2 of 2, by thunderbird32
As far as drivers go, there are of course the Windows 1.x drivers you found, and also AutoCAD 2.62 natively supports the card. There are supposedly Windows 2.x drivers, but no one seems to have them. Only the Windows 1.x drivers work in emulation, but the latter could be helpful for you.
