First post, by Intel486dx33
Hello,
I have a new project.
The Ultimate AMD 5x86-133@160mhz.
Specs:
Motherboard - Lucky Star LS-486 revision-E
CPU - AMD 5x86-133 - ADZ overclocked to 160mhz.
Chipset - SIS
Memory - 32mb EDO
Harddrive - 8gb CF , 133
Graphics - S3 trio64, 4mb.
Sound card - ?
CDROM drive - Sony 24x
I need help choosing a sound card or two.
What I have:
1) Sound blaster 16 with OPL3 ( CT2890 )
2) Turtle Beach Monte Carlo with OPL3 ( Crystal CS4248-KL)
3) Media Vision PAS16
Purpose :
DOS gamer / Music play and recording.
Reply 1 of 16, by pshipkov
In my opinion and experience, there is no single ultimate 486 system.
- Best DOS graphics are achieved with ASUS VLI-486SV2GX4 (some late revision will be best) + ARK1000VL VGA.
- Best Windows GUI graphics are achieved by plethora of well designed motherboards (including yours) based on late SiS or UMC chipsets in combination with Matrox Millennium 1/2/x VGA - assuming you are trying to stay period correct-ish. Otherwise any late PCI video cards will be similar, or better.
- Best computation performance is achieved with ASUS PVI-486SP3.
That is if you want to stick to "486".
Otherwise "best" seems to be a combination of motherboard with bus clock divider option + overclocked Cyrix 5x86 CPU with BP and other Pentium-like features enabled.
retro bits and bytes
Reply 2 of 16, by Intel486dx33
Well, I have this computer built already.
and it is running steady.
topbench score was 173
but on my other AMD 5x86-133 over clocked at 166mhz I get a score of 198 in topbench
But 173 is good enough for me.
I know there are many different combinations to go with using other motherboards.
But I am sticking with this motherboard and CPU.
the score of 173 was the most stable and constant so I am sticking with these settings.
I am just going to run DOS 6.22 and maybe Win3.11
But NO Win95.
What I want is a very good DOS gaming computer and DOS Audio studio.
So I saw online that the Sound Blaster CT2890 was a good card.
I don't know if I should add the Turtle Beach Monte Carlo too or do I not need it ?
But I like the clarity of the Crystal chips.
So any recommendations in Audio and Graphics will be appreciated.
For graphics I want to use PCI card.
I was thinking about adding both sound cards with wave tables.
Yucatan FX for the turtle beach Monte Carlo
and the DreamBlaster x2 for the Sound Blaster.
    19.98 KiB
    184.75 KiB
Reply 3 of 16, by bloodem
Sorry for being off-topic, but does this motherboard have a PS/2 mouse header?
Somebody in my hometown is selling it for $10 (with an Intel DX2-66 + 16 MB FPM), which is an extremely good deal... but I already have a bit too many 486 PCs. 😀
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 4 of 16, by Intel486dx33
No, but they do sell adapters for this.
Reply 5 of 16, by pshipkov
Late S3 Trio/Virge or Matrox PCI cards will be more than enough then.
Will let others comment on the sound options. Not sure what the MC audio card will do for DOS stuff, but if you have it - why not ?
I cannot remember seeing compact LuckyStar boards with PS2 connectors. This one does not have it either.
Reply 6 of 16, by Intel486dx33
pshipkov wrote on 2021-01-29, 18:43:
Yeah, must be for a Win95 keyboard.
This motherboard bios reads 1997 ?
But it’s a cross between Win3x and Win95 compatibility so they just went with the Serial ports.
But this motherboard is really easy to setup. Easier than a VLB motherboard and provides faster performance.
Reply 7 of 16, by bloodem
Intel486dx33 wrote on 2021-01-29, 18:41:
Actually, no. Those adapters only work with mice that support both the PS/2 and serial protocols.
Since I mostly use newer optical PS/2 mice.... those adapters are a no go. 🙁
I do have some NOS serial mice as well, but I prefer to have one mouse to rule them all (also... the ball - I hated it 30 years ago, and I hate it now!) 😀
Reply 9 of 16, by The Serpent Rider
Another generic "PC build X" theme with random pics from internet which ultimately leads to nowhere, eh.
Actually, no.
Actually, lol. Listed pic is serial mice to PS/2 port adapter.
Reply 10 of 16, by Intel486dx33
pshipkov wrote on 2021-01-29, 19:12:
Yes.
They were a bit on the "value" side - compact, limited list of features, but otherwise stable and with good performance.
Yes the motherboards with the “ALi” controller appear to preform better in over clocking the AMD 5x86.
Reply 11 of 16, by bloodem
The Serpent Rider wrote on 2021-01-29, 21:46:
Actually, 🤣. Listed pic is serial mice to PS/2 port adapter.
What do you mean? The pic I'm seeing, the one posted by Intel486dx33, is of a female PS/2 to female DB9 (so a normal PS/2 to serial adapter).
Reply 12 of 16, by Intel486dx33
Up until 1995 it was mostly Serial ball mice.
    109.28 KiB
Reply 14 of 16, by Intel486dx33
Okay guys,
I have the Monte Carlo setup and working good.
But I had problems with the CT2890 which is a Plug and Play card.
When I put it in by itself with NO other cards but video card the computer would not detect it.
The Motherboard is plug and play too but I am only running DOS 6.22
So I ran the Sound Blaster Vibra install program but it would not detect the card.
I received the error “DMA channel not available or card is not installed” I tried all DMA channels.
But I think the problem is the motherboard is not detecting the sound card.
I tried other ISA slots too with no success.
You can assign IRQs to the ISA slots in bios and I tried that too with no success.
The strange thing is that the Turtle Beach card worked with no problems.
I have two of these CT2890 and I tried both with no success. Same error messages.
So for some reason the Creative sound blaster “Diagnose” program is NOT detecting the card.
Any Ideas ?
