First post, by Dragonslayer182
Hello, I have a Thinkpad T30 that I'm thinking of putting Windows 98 on. Unfortunately, it has a messed up headphone jack, and the dock's headphone jack has terrible sound quality (Not to mention the dock is too bulky anyways). I would like to get the SB Audigy 2 ZS PCMCIA version working under windows 98, but I don't know if drivers even exist for that. I have the card fully working under XP, so no issues there. Is there any way I can do this?
Model number is SB0530, if that helps.
    41.3 KiB
Discord: Dragonslayer182#8984
Reply 2 of 10, by Warlord
I've read many times its not. But thats not to say how hard the people tried to get it working. One of these days I'm going to get around to fully trying it.
WMD drivers should work. It's the vxds that people say don't.
Reply 4 of 10, by cyclone3d
I tired mixing drivers but could never get it to work in 98SE.
The original driver CD has the 9x driver for the gameport on it which it doesn't even have but nothing else prior to Win2x/XP.
The CDs for both the retail box and the clamshell packaging are the same. I have both.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 10, by Dragonslayer182
Alright, I suppose this card is out of the question for 98 gaming. Are there any 98-compatible PCMCIA sound cards that I could use?
Reply 6 of 10, by darry
Dragonslayer182 wrote on 2021-03-11, 04:46:
Why not get a modern USB sound device that is class compliant (https://www.cambridgeaudio.com/usa/en/blog/ou … should-i-use-it) and use that ? They work under Windows 98 SE and ME, at least . See Re: need temporary sound
Reply 7 of 10, by Sphere478
darry wrote on 2021-03-11, 05:17:
a Audigy would be nice for cpu offloading. too bad it sounds like it won't work.
Sphere's PCB projects.
Reply 8 of 10, by darry
Sphere478 wrote on 2021-03-11, 06:28:
IMHO, before wishing for CPU offloading, just finding a card that
a) is Cardbus compatible (the T30 has a Cardbus slot see http://www.thinkwiki.org/wiki/CardBus_slot and has backwards compatibility with PCMCIA, AFAICT)
b) has Windows 9x drivers
c) is actually available for purchase
d) is not being sold for an insane price
is challenge enough .
Once you get a list of those, you can start comparing feature sets and nice things to have . On Ebay.com , for example, there are currently two matches if we consider only "a" and none if we consider any of the other criteria .
Class compliant USB audio devices are virtually guaranteed to work, plentiful and cheap . If nothing else, one can be used as a temporary solution until something better is found .
Reply 9 of 10, by lolo799
There are many, look at the link in my signature.
Finding one isn't easy, finding one that does everything you want is harder.
Reply 10 of 10, by cyclone3d
And finding one for a good price is the hardest though they do pop up every once in a blue moon.
YMF7x4 Guide
