First post, by Woody72
Hi guys, I rescued this from the WEEE waste pile at work and would love to know what it is, Google wasn't much use at all surprisingly. I know the i960 is a RISC based processor and was often used in military applications but other than that it's a bit of a mystery:
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
Reply 2 of 8, by hyoenmadan
It has Brooktree DAC and Genlock. Most probably it is an analog image acquisition card, probably for some expensive lab or industrial equipment...
Reply 3 of 8, by Unknown_K
Not a TV tuner card, probably some kind of capture card or data processing card.
Reply 4 of 8, by debs3759
hyoenmadan wrote on 2021-04-25, 19:34:
The DAC is used to convert digital signals to analog to output over the VGA port. Other than that, I have no idea either.
Reply 5 of 8, by Woody72
Cheers guys, I think you're all in the right ballpark. Whatever it is, it was used in the nuclear industry so some kind of image aquisition card makes a lot of sense.
Reply 6 of 8, by snufkin
Looks like there was a 4C's company registered in postcode SL6 6RZ (written down near the connector), Maidenhead. Wound up in 2016. Can't find anything about what they did.
